DNHunt
Feb 16 2006, 02:57 PM
The car is a street car with an occasional AX. 19mm Master cylinder, ATE 320i front calipers, stock 914/4 rear. I have rubber brake hoses.
I'll check everything but the plan is not to open the lines just pump the new stuff through. I can't remember what is currently in there but it was new just prior to WCC 04.
Dave
TravisNeff
Feb 16 2006, 06:09 PM
Plus the synpower can be found just about anywhere (FLAPS) for about 7 bux for a big bottle
TimT
Feb 16 2006, 08:48 PM
Motul is a good fluid, BUT if your using the Motul fluid I suspect.. you cant think about using another fluid to top up, and Motul recommends a complete flush of the old fluid before adding Motul..
Also if you maintain your brakes properly, you can ignore the wet boiling point
Trekkor
Feb 16 2006, 11:22 PM
I bleed my brakes before every event. So the fluid is always fresh Motul
KT
