pnewman
Feb 20 2006, 03:39 PM
I am in the midst of doing a fuel pump relocation and wanted to know if I could use the smaller cylindrical fuel pumps to replace my 3 hose L jetronic pump. I have a 1974 1.8 liter.
Thanks in advance for any input.
Bleyseng
Feb 20 2006, 03:58 PM
Thats what Porsche did for the 75-76 cars when they stuck it upfront.
Use the inline pump and the inline filter with the larger feed hole.
Cap'n Krusty
Feb 20 2006, 04:08 PM
QUOTE (pnewman @ Feb 20 2006, 01:39 PM) |
Thanks in advance for any input. |
The single-in/single-out VW pump will work fine, but it's the same size as the 3-line one. Porsche went to that pump for the 75-76 cars. If you're thinking of one of the smaller aftermarket pumps, probably not. You need to match up the pressure/flow with what you have. The Cap'n
pnewman
Feb 20 2006, 10:07 PM
QUOTE (Cap'n Krusty @ Feb 20 2006, 02:08 PM) |
QUOTE (pnewman @ Feb 20 2006, 01:39 PM) | I am in the midst of doing a fuel pump relocation and wanted to know if I could use the smaller cylindrical fuel pumps to replace my 3 hose L jetronic pump. I have a 1974 1.8 liter.
The single-in/single-out VW pump will work fine, but it's the same size as the 3-line one. Porsche went to that pump for the 75-76 cars. If you're thinking of one of the smaller aftermarket pumps, probably not. You need to match up the pressure/flow with what you have. The Cap'n |
What is the GPM and PSI rating of my oem pump?
What are the GPM and PSI requirements of my 1974 L Jetronic system for my 1.8 liter?
Is it that easy to find out GPM and PSI ratings of after market pumps? or other year 914's?
thanks
bd1308
Feb 21 2006, 06:17 AM
on my 914, I have a fuel pump from a 97 Ford Ranger, being fed from a line with a 914 stock fuel filter, then going way back and then going to a 300ZX fuel filter...
whole setup cost 100 or so dollars...been working solid for a dialy three months.
As dependable as a.....a.....honduh
b
pnewman
Feb 21 2006, 09:18 AM
QUOTE (bd1308 @ Feb 21 2006, 04:17 AM) |
b |
What fuel delivery system are you running?
Carbs?
L jet?
D jet?
bd1308
Feb 21 2006, 10:35 AM
I'm using L-jet, but I went ahead and mounted everything up front (except for fuel filter #2) so I could get rid of the vapor lock issues....or at least that was the excuse I was using...shoudl work *EXACTLY* the same with D-jet, and if you purchased a regulator that would cut the pressure down to 3-4 psi from the FI pump, you could run carbs.
b
pnewman
Feb 22 2006, 10:25 PM
QUOTE (bd1308 @ Feb 21 2006, 08:35 AM) |
b |
So you think that the D jet fuel pump would work fine mounted up front w/ the L jet EFI system?
I like that pump better. It seems as though it would be easier to service it than the 3 hose oem L jet pump.
thanks
Air_Cooled_Nut
Feb 23 2006, 06:12 AM
The fuel pump from a fuel injected VW Type 3 should work. D-jet system w/three ports on the pump.
Nothing magical or extra difficult with a three port pump
pnewman
Feb 23 2006, 07:40 AM
QUOTE (Air_Cooled_Nut @ Feb 23 2006, 04:12 AM) |
Nothing magical or extra difficult with a three port pump |
I guess that you hit it on the head! about the 3 port "magic"
Cylinder pumps seem to be the way now.
what's up w/ 3 ports!
anyone know the psi and gpm of the old 3 port pumps?
Cap'n Krusty
Feb 23 2006, 08:05 AM
b |
Dropping the pressure from an FI pump down to 3-4 PSI is a well known way to prep for a fire. Seen several carbecues done that way . The Cap'n
Cap'n Krusty
Feb 23 2006, 08:07 AM
QUOTE (pnewman @ Feb 22 2006, 08:25 PM) |
QUOTE (bd1308 @ Feb 21 2006, 08:35 AM) | I'm using L-jet, but I went ahead and mounted everything up front (except for fuel filter #2) so I could get rid of the vapor lock issues....or at least that was the excuse I was using...shoudl work *EXACTLY* the same with D-jet, and if you purchased a regulator that would cut the pressure down to 3-4 psi from the FI pump, you could run carbs.
b |
thanks |
As previous replies have stated, the later D jet cars used that pump, as did the L jet cars through the VW Vanagons. The Cap'n
bd1308
Feb 23 2006, 12:53 PM
QUOTE (Cap'n Krusty @ Feb 23 2006, 08:05 AM) |
b |
Dropping the pressure from an FI pump down to 3-4 PSI is a well known way to prep for a fire. Seen several carbecues done that way . The Cap'n |
I agree it would be stupid to do that, but it is possible to do.
b
