Good morning.
I've begun researching installing a shorter spring (which may mean heavier load - not sure) in the rear of the 914. I've never been happy with the way it sits up "higher" that I think it should.
Not looking to fork over $$$ for coilovers...... just a shorter spring.
I'm running 205s on all 4 corners, and there is VERY little clearance in the rear between the tire and the outside fender.
I remember when I installed drop springs on the Acura, The front tires were fine, but the rear camber kinda "kicked out" a bit..... caused the inside edge of the rear tires to wear unevenly.
What should I expect? Uneven tire wear? Negative camber? Positive camber? No change at all?
Thanks!
