[quote name='carreraguy' date='May 17 2006, 12:33 AM' post='681361']
[/quote]
would you mind sharing the price tag for letting renegade do the conversion? I have tried to search for it and when I emailed they said $20K which I think is
Thanks
Looking great!
[/quote]
Thanks! The price they quoted is indeed in the ballpark - why would they tell you otherwise?
You may call it BS but it penciled out for me. I wanted a 914 with more horsepower, thus I was looking for a 914/6 or a 914/6 conversion. A 914/6 in good condition with a 30 year old engine would cost a minimum of $20K and still have some issues. A 914/6 conversion with 260HP (what I can get from the 2.0 WRX turbo) would cost about $35K complete turn key with a brake/handling upgrade and the weight difference would be about 150 pounds heavier. So, I would need another 75 hp (approx) to overcome the additional weight and match the straight line acceleration. Add another $5K to the final bill for the needed bump in hp, so then you're up to $40K. Then, because you wouldn't corner as well due to the extra weight, you would need to add another $5K to get more hp out of the Porsche motor to overcome the slower cornering speed. So then you are up to $45,000.
Bottom line, I'm getting a lighter, better handlling car whose performance will be better than a 914/6 with a very reliable and more modern powerplant; i.e. I will not be relying on a 30 year old engine that will likely cause more maintenance $$ downstream. On top of all that I'll get better mileage! Granted I'm loosing the panache of having a "pure" 914 but I'm not planning on doing PCA events for points; i.e. "fun runs" only at the autox, that s fine with me. I'll just have a NARP that'll be NARPier than yours - a double NARP!
Should have 914AROO by mid-June; we can compare notes at the WCC!
[/quote]
Great work looks very nice. I am curious about weight advantage over six. When you factor in intercooler, turbo plumbing, radiator plumbing and water, conversion plate does the subaru engine conversion beat six weight by 150 lbs?
