Full Version: What's the Official Name for "Taco Plate"
vesnyder
Went to Stoddard at lunch today and they were clueless? The cover did not appear in his engine blow-up and I was not much help? Anybody have a part number and/or source? Your help is appreciated!
Aaron Cox
engine sump temp sender plate?
TROJANMAN
Aaron Cox
PET calls it "cover for oil sump" and "cover for oil temperature sender"
Allan
Not sure what Porsche calls it but if you tell them to look up oil temp sender they should see an exploded view of the immediate area. Tell them it's the plate that the sender mounts to.
Aaron Cox
QUOTE (Aaron Cox @ Mar 9 2006, 02:32 PM)
tat2dphreak
Temp Adapter Connection Orafice Plate?
Jimz73
Pelican Parts sells the rubber o-ring you're looking for. It's part # OEM-021101269A. They told me that the two copper washers are NLA, so I reused mine. The old o-ring didn't look bad, but a new one was only $ 5.88.
Regards,
Jim
Jake Raby
I carry them and I have the copper crush washers that are NLA as well....
type47
cover for telethermometer?
Joe Ricard
Do you need the rubber O-ring? part #50 in Aarons pic post.
or the paper piece that goes between the two plates. cut a paper one from a sheet of gasket paper available at NAPA or other FLAPS.
and that pic looks different than my set up wacko.gif I have a cover that goes over all that is depicted above.
Howard
QUOTE (tat2dphreak @ Mar 9 2006, 01:34 PM)
happy11.gif Get out more often!
tat2dphreak
QUOTE (Howard @ Mar 11 2006, 10:19 PM)
