bd1308
Mar 12 2006, 11:08 PM
okay the piston keeps sticking....very hard to move either way...last time they were out dralf and I saw that some scaling and/or corrosion developed on the piston....and i guess its the same way now....
I am getting a rebuild kit, but do I need to purchase a new caliper piston or can I use the piston i have now and just clean it up?
b
bd1308
Mar 12 2006, 11:09 PM
and i guess the corrosion develops from water getting in there?
b
TimT
Mar 12 2006, 11:10 PM
QUOTE |
or can I use the piston i have now and just clean it up? |
Post hi res pics grasshopper
Cant recommend if you can reuse or not if I (we) havent seen it
Aaron Cox
Mar 12 2006, 11:13 PM
QUOTE (TimT @ Mar 12 2006, 10:10 PM) |
QUOTE | or can I use the piston i have now and just clean it up? |
Cant recommend if you can reuse or not if I (we) havent seen it |
werd
if it is just minor, no pitting or deep scratches or corrosion........ i used like 2000 grit sand paper and polished them. and then cleaned them with laquer thinner....
make sure you make a template to align the piston.....
i think its on pelican.
bd1308
Mar 12 2006, 11:15 PM
uh, they're on my DD as we speak...uh,um how much are new pistons....I think I should get new ones, while i'm rebuilding the caliper....
b
