caliper issue |
caliper issue |
bd1308 |
Mar 12 2006, 11:08 PM
okay the piston keeps sticking....very hard to move either way...last time they were out dralf and I saw that some scaling and/or corrosion developed on the piston....and i guess its the same way now....
I am getting a rebuild kit, but do I need to purchase a new caliper piston or can I use the piston i have now and just clean it up? b |
bd1308 |
Mar 12 2006, 11:09 PM
and i guess the corrosion develops from water getting in there?
b |
TimT |
Mar 12 2006, 11:10 PM
Post hi res pics grasshopper Cant recommend if you can reuse or not if I (we) havent seen it |
Aaron Cox |
Mar 12 2006, 11:13 PM
werd (IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) if it is just minor, no pitting or deep scratches or corrosion........ i used like 2000 grit sand paper and polished them. and then cleaned them with laquer thinner.... make sure you make a template to align the piston..... i think its on pelican. |
bd1308 |
Mar 12 2006, 11:15 PM
uh, they're on my DD as we speak...uh,um how much are new pistons....I think I should get new ones, while i'm rebuilding the caliper....
b |
Lo-Fi Version | Time is now: 9th May 2024 - 05:26 PM |
