guiltless
Mar 13 2006, 10:40 PM
For whatever reason I cannot get the driver's seat the hell out of my car. Is there any special trick to it?
smooth_eddy
Mar 13 2006, 10:44 PM
Slide the seat back. with a flashlight look b/t the rails for the spring pin. the spring pin is located on the outer rail. use a screwdriver to lift it up and then slide the seat forward. It will come right out.
guiltless
Mar 13 2006, 10:59 PM
Awesome. I will give it a shot asap.
Mar 13 2006, 11:07 PM
QUOTE (smooth_eddy @ Mar 13 2006, 08:44 PM) |
Slide the seat back. with a flashlight look b/t the rails for the spring pin. the spring pin is located on the outer rail. use a screwdriver to lift it up and then slide the seat forward. It will come right out. |
gotta push the metal springy-thingy up while sliding the seat forward .....
Andy
Andyrew
Mar 14 2006, 02:42 AM
Trick is move it all the way up, then one notch down, Hold the spring up with one hand, and the lever with the other while giving a good tug.
should come out!
