I'm going to post this same message here as I did on the Resource thread... I need some experienced BTDT's
Help me out gang... I want to get this now but I'm not there yet on the car. I need to know exactly what I'll need.
I'm running a 914-6 pump in the front trunk.
I want to run Aeroquip lines (or do I?)
I'm running Weber 40IDA3C's
I think I only need the long line with the -6AN connections. What can be done on the pump end with the -6AN lines? I've seen a Burmos car with them and it looks like they're on a stock pump.
What about the tank fittings? Chris, I imagine you can weld the AN fittings on the tank elbows...?
So for this pump set up, do I have this right?
1 short delivery line through the bulkhead to the pump (-6AN from the modified tank feed to the pump)
1 long line to feed the fuel to the engine compartment (-6AN off the pump to a -6AN in the engine compartment)
1 short return line from the pump through the bulkhead to the tank return (-6AN from the pump to the modified -6AN return feed on the tank)
I think that's it but I still have the question about the -6AN lines and their termination points at the pump and the carbs. Who's BTDT??
Chris, help me price this damn thing out!
Should I just go with standard fittings and use the stock rubber hose connections??
