Ive read a few times that Bus CV's are a viable replacewment for the NLA teen'er CV Joints.
Are they a direct replacement or is there mods necessary along the lines of Andy's 944 abortion...err, updates?
QUOTE (pete-stevers @ Mar 30 2006, 01:22 PM) |
i have bus cvs in my car, i think that they are a mil or two wider....but they work fine |
QUOTE (joefri187 @ Mar 30 2006, 05:45 PM) |
I am using type II axles on my V8 conversion. Type II CV's are 6 bolt and the axle assembly is shorter than the 914. You need adapters to make it work. Renegade Hybrids makes a kit but it is $$$. They won't sell just the adapters. The Type II axles are cheap, so I had some adapters machined and saved some money. |
QUOTE (jsteele22 @ Mar 31 2006, 04:48 PM) |
Bump for myself ;) I've been reading back through the archives, and re-reading this thread, and I've got one more qustion. It sounds like the bus CV will fit directly to the 914 stub axle (no adapter) if two of the bolt holes in the CV are drilled out to accept the roll pins. Q) Is this really true ? In the photo of the adapters in this thread, it looks like the bolt circle is not quite the same, but Porcharu says the bolt pattern is the same. And Porcharu, if the pattern is the same, then when you say that it is not a bolt-on replacement, do mean because of the width (thickness) of the bus CV joints and the need to drill out the roll pin holes ? I'm thinking of this for a Subie tranny, so the axle length issue would be made up at the inner CV adapter. |
QUOTE (Andyrew @ Apr 1 2006, 06:09 PM) |
The hole in the middle eliminates that big chunk of heavy steel on your rotating assembly.. |
