Full Version: Jake's full flow oil conversion
Dave Bell
Anybody here install Jake's full flow oil pump conversion?
Can't find much on line... maybe I am not looking hard enough.
Where does the filter go when stock connection is blocked off? separte mounting site?
I see his kit on the site for about $130. Is that all that is needed?... going into a currently cleaned out case.
Any other cleaning/clearancing of passages that are recommended?
Any 914 specific issues?
Some one give me a data dump.
URY914
I have a Jake engine but I don't kow if this set up is the same one you're looking at. It is a full flow w/o the filter in the stock location. Mine is remote. Here are some pics...
URY914
nutter
URY914
Look close at the negine mounting angle. Needs to be modified.
URY914
my filter...
URY914
Makes it easy to stick a remote cooler in line also (but I don't run one)
