Here is my side seal, kind of tough getting it in with everything in the way, I still need to add some screws to the end of the metal strip to keep everything in place.:
Click to view attachmentI already installed the plate I made so the pictures are a
little hard to make out. It looks like a three sided box. One side is welded to the J-tube:
Click to view attachmentAnother side of the boxes faces toward the center of the car. It is cut even with the end of the oil cooler and has a slot cut out for the drive belt.
Click to view attachmentThe third side of the box wraps around the back of the compressor. Toward the upper right of the picture is the fan shround and the upper left is the back of the compressor:
Click to view attachmentThe heater valve is wedged right under the plate. It is a very tight fit but doesn't seem to rattle:
