Downunderman
Sep 18 2003, 05:23 PM
Hi guys,
I am after some slightly larger diameter cam chain idler wheels to take up the slack in the chain when I up the compression. Does anyone over there know who makes/sells them?
How
TimT
Sep 18 2003, 05:39 PM
Your not really supplying enough info.
What year 911 engine?
Lowering the deck height to raise the CR is NOT the way to get increased CR on a 911 engine.If you machine to much from the heads, the tensioners run out of stroke and you get into all sorts of problems.
A real inexpensive part of a good 911 rebuild is to replace all the ramps,the chains, and update to post '80 idler arms. Money well spent
An easy way to increase CR without fucking up the chain geometry is to offset bore the connecting rod small end. have some larger wrist pin bushings mader and they can be offset reamed as well to get some CR..
Another way to increase CR is to get some high compression Mahles or JE's
Larger dia chain wheels are a bandaid
Brad Roberts
Sep 18 2003, 11:24 PM
What Tim said..
I know your the type to do right one time..
B
ChrisReale
Sep 18 2003, 11:49 PM
Bruce Anderson says German Precision in Sunnyvale makes somethingf like this.
Phone; (408)747-0728
Fax: (408)747-0782
From second edition of 911 performance Handbook
Brad Roberts
Sep 19 2003, 12:08 AM
If you have to have them......Ask for Ted (he will probably answer the phone) Ted does all of our 911 heads and twin plugging.
B
