QUOTE(lapuwali @ May 27 2006, 07:39 PM)
The missing fuses are why you have no lights. The first four fuses control each headlight (left and right), and high and low beams. The white wires are high beams, the yellow wires are low beams.
The fuses may be missing because they kept blowing, because the light switch is dangling from its wires rather than mounted, and not all of the wires are in place.
If you do a search, there's a photo of the headlight switch with all of the terminls clearly numbered. Match those numbers up with the small numbers on the wiring diagram to get the appropriate color of wire that supposed to go on each terminal (it's not the same for all years).
Thank you very much! I replaced the fuses, and now have everything except for driver high beam - I should be able to trace that down.
FYI - the thread with the switch labels seems to be missing some of it's photos (I needed a shot of the early switch):
http://www.914world.com/bbs2/index.php?show...eadlight+switch
