QUOTE(So.Cal.914 @ May 3 2006, 09:16 AM)
Could you please explain that first 90 degree turn to get to the exhaust valve?
OK, but as you can see from Paul's description above, it's not that relevant to the actual flow of things. (I didn't have time to get into that when I posted earlier...)
Note that the valves on the VW air-cooled motors are side by side. If you check the #1 (left-front in a 914) cylinder, the intake valve is toward the rear of the car and the exhaust valve is toward the front. The air comes in through the intake port in a close to vertical direction (vertical and pointing inward some). The exhaust valve, however, is aft of the intake valve. So the flow would have to take a step to the side to get out of it.
But again--that's not relevant to the real flow through the head. It would be nice if we had valves that "faced" each other more, and flow paths that also "faced" each other--but I believe that's mostly so the incoming air charge can help cool the hot exhaust valve. (Look up "cross-flow head" for more info on that.) But that's not what we have, and that's not what we're gonna get. So it's not really relevant either...
--DD
