I'm going to attempt to change my tranny mounts with some 911 sport mounts I got from Pelican. I think I'm removing the two small 15mm bolts that hold the mounts to the chassis while supporting the tranny with my jack? Anyway, will the old mounts just simply pull thru the ears forward? I assume I've got to drop the tranny a bit to clear the supports on the chassis, is this correct? What about the big bolt, do I gotta loosen it? What am I missing?
Thanks,
Kevin
