aveale
May 23 2006, 07:15 AM
cant think this one through.
anyone know what could cause an orange film (consistency of the Orange Milk Shakes from McDonalds) on the inside of the oil filler cap, and lining the filling neck?
Thanx in advance.
T
Marlow
May 23 2006, 07:30 AM
Lots of short trips can cause this. I don't know the exact science of it but it's something like this; the oil doesn't get hot enough to burn off the condensation, it foams up and ends up in your oil cap.
This happens in my truck since I only drive about 2 miles to work everyday.
drgchapman
May 23 2006, 07:40 AM
Sounds like water to me. Condensate likely.
DonTraver
May 23 2006, 07:44 AM
Yep, condensation, too many short trips. Change your oil more often than normal or take her out for a good drive.
It takes 10-15 miles for a engine to get up to full operating temp, then it will start gassing off the condensation.
Short trips will also increase carbon formation on pistons and cylinder heads, foul plugs, just not good for your engine, drive it more.
Don
Hammy
May 23 2006, 07:46 AM
QUOTE(DonTraver @ May 23 2006, 06:44 AM)
drive it more.
don't hear that every day
aveale
May 23 2006, 07:51 AM
Perfect!!
I Love this place!
Joe Ricard
May 23 2006, 09:30 AM
Yup drive it like you stole it.
I get this build up once in while.
After coming back from a track day the cap was spotlessly clean.
I guess 260 degree oil will burn off all the moisture.
yarin
May 23 2006, 11:04 AM
If its a water pumper then I'd say bad headgasket or coolant leak into the oil somewhere.
jsteele22
May 23 2006, 02:03 PM
QUOTE(DonTraver @ May 23 2006, 07:44 AM)
Don
Also, exhaust system doesn't warm up, resulting in condensation which leads to rust.
bd1308
May 23 2006, 02:05 PM
I had the same occurance, but I drove more than 15 minutes per trip.
b
spunone
May 23 2006, 02:08 PM
Yep my water cooled Forklift has the same problem so called repair man said blown head gasket NOT just from lack of use no real warm up time
JohnM
May 23 2006, 06:06 PM
Could be bad PCV valve or kinked hose between PCV valve and intake plenum (moisture build-up is a sign of Crankcase not venting at all or enough). John
TimT
May 23 2006, 07:14 PM
Its called spooge
removed by warming the engine more thoroughly
Joe Ricard
May 23 2006, 07:41 PM
I got a better way of getting rid of excess spooge.
But usually driving does the trick
