What the heck?, Film on inside of Oil filler cap and neck |
aveale |
May 23 2006, 07:15 AM
Fun Times Group: Members Posts: 194 Joined: 18-August 04 From: Ottawa, Canada Member No.: 2,563 |
cant think this one through.
anyone know what could cause an orange film (consistency of the Orange Milk Shakes from McDonalds) on the inside of the oil filler cap, and lining the filling neck? Thanx in advance. T |
Marlow |
May 23 2006, 07:30 AM
Member Group: Members Posts: 311 Joined: 14-August 03 From: Manassas, VA Member No.: 1,027 |
Lots of short trips can cause this. I don't know the exact science of it but it's something like this; the oil doesn't get hot enough to burn off the condensation, it foams up and ends up in your oil cap.
This happens in my truck since I only drive about 2 miles to work everyday. |
drgchapman |
May 23 2006, 07:40 AM
Current Stable Group: NoClassifiedAccess Posts: 922 Joined: 20-September 04 From: Portland, OR Member No.: 2,789 Region Association: Pacific Northwest |
Sounds like water to me. Condensate likely.
DonTraver |
May 23 2006, 07:44 AM
Senior Member Group: Members Posts: 829 Joined: 5-August 04 Member No.: 2,461 |
Yep, condensation, too many short trips. Change your oil more often than normal or take her out for a good drive.
It takes 10-15 miles for a engine to get up to full operating temp, then it will start gassing off the condensation. Short trips will also increase carbon formation on pistons and cylinder heads, foul plugs, just not good for your engine, drive it more. Don |
Hammy |
May 23 2006, 07:46 AM
aveale |
May 23 2006, 07:51 AM
Perfect!!
I Love this place! |
Joe Ricard |
May 23 2006, 09:30 AM
Yup drive it like you stole it.
I get this build up once in while. After coming back from a track day the cap was spotlessly clean. I guess 260 degree oil will burn off all the moisture. |
yarin |
May 23 2006, 11:04 AM
'14-X'in FOOL Group: Members Posts: 988 Joined: 13-May 03 From: Guttenberg, NJ Member No.: 693 Region Association: North East States |
If its a water pumper then I'd say bad headgasket or coolant leak into the oil somewhere.
jsteele22 |
May 23 2006, 02:03 PM
Senior Member Group: Members Posts: 727 Joined: 24-August 05 From: Colorado Springs, CO Member No.: 4,653 |
bd1308 |
May 23 2006, 02:05 PM
I had the same occurance, but I drove more than 15 minutes per trip.
b |
spunone |
May 23 2006, 02:08 PM
Senior Member Group: Members Posts: 945 Joined: 6-April 04 From: Anaheim CA Member No.: 1,901 Region Association: Southern California |
Yep my water cooled Forklift has the same problem so called repair man said blown head gasket NOT just from lack of use no real warm up time
JohnM |
May 23 2006, 06:06 PM
914 enduro driver Group: Members Posts: 179 Joined: 23-July 04 From: San Diego Member No.: 2,387 |
Could be bad PCV valve or kinked hose between PCV valve and intake plenum (moisture build-up is a sign of Crankcase not venting at all or enough). John
TimT |
May 23 2006, 07:14 PM
Its called spooge
removed by warming the engine more thoroughly |
Joe Ricard |
May 23 2006, 07:41 PM
I got a better way of getting rid of excess spooge.
But usually driving does the trick |
Lo-Fi Version | Time is now: 15th May 2024 - 06:11 PM |
