nycchef
May 24 2006, 04:02 PM
okay changed the cht, set the dwell, idle, timing, new points ,plugs, dizzy, fuel lines,vacuum hoses, lowered fuel pressure to 30 psi, reepoxyed the gas tank,new fuel filter, new tires even armoralled the interior and it still won't go past 4000 rpms. help
nycchef
May 24 2006, 04:07 PM
QUOTE(Leo Imperial @ May 24 2006, 02:05 PM)
Tach working properly?
think so runs right up to 6000 in nutral. gas pedal sticks a bit can't be that simple
Leo Imperial
May 24 2006, 04:32 PM
Since you just insulted powder blue cars without knowing this is my car, so fix it yourself. Blue is faster and orange doesn't run past 4000 rpm
nycchef
May 24 2006, 04:49 PM
QUOTE(Leo Imperial @ May 24 2006, 02:32 PM)
that is the most beautiful color i have ever seen screw the valves i'm gonna repaint mine first
So.Cal.914
May 24 2006, 06:14 PM
QUOTE(nycchef @ May 24 2006, 03:49 PM)
Just something to look at, Is the dissy advancing? They can get FUBAR inside
and not work. Something to look at.
porschenut
May 25 2006, 04:30 AM
At least once you find the problem you will have taken care of lots of other things that also would have broken.
Distributor advance, plug wires, valve springs broken, clogged injectors, or my favorite they sealed the wire mesh sock inside the tank during the coating process.
Try looking at the plugs to get a clue of whats going on. Probably won't help, but worth a look.
You need to isolate fuel vs ignition. Check timing at 5000rpm, see if full advance is coming in. Play with fuel presure and adding resistors in the CHT sensor line to richen it and see if the problem goes away.
