QUOTE(Mueller @ Jun 7 2006, 09:50 PM)
QUOTE(Mark Henry @ Jun 7 2006, 11:44 AM)
QUOTE(lapuwali @ Jun 7 2006, 01:39 PM)
...The main thing SDS will buy you is handholding from SDS.
actually I think James meant that as a positive
support is a
huge factor unless you are an expert...as much as I like the MS, there is no real 100% guaranted support..posting questions on msefti.com is a crap shoot at times, you have to word your question just right and at the right time and place, otherwise you get the chance of getting no response at all....
Support for LINK has been okay, limited hours (luckly same time zone as me), but nothing on the weekends....
Sorry James...thought it was a put down... what are you starting to like the system?
Is SDS the best system on the market?
No, Like David said it's not a Motec. It can't control a VTEC, it doesn't have traction control, big spread sheets, it's not waterproof, no sequential injection, etc. They are up-front about this.
EDIT I've been told SDS will run VTEC...not that it matters to this crowd.
But what it does have going for is it's programming simplicity, you don't have to be a geek or need a dyno to program it. One guy driving around can fine tune the program pretty good in about a half hour or so.
Price is competitive and certainly lower than the high-end systems out there
and the price is up-front and on their website.
It's reliable, so it doesn't need a limp home mode. (it's in severial homebuilt planes)
Tech support and service is second to none.
They have a no BS business model, although they have had very few problems they do have bulletins on how to fix or avoid any issues.
They will fix what they sell, of course if it's your bad they will charge you, but I KNOW Ross will eat the shipping (both ways, Fed-Ex) if it's their bad, as I got the only bad WB meter (lambda issue) they've sold. I had a new one in 2 days.
They do have data-logging now and for $94 you can re-chip your older EM-4 or EM-3.
They also have an open forum, you can download their manual, they will support 2nd hand units, I could go on and on.
Every one I've sold has had positive result.
I wish that the rest of the aftermarket were just half as good as these guys.
