Full Version: oh noooo...broke my new to me exhaust already
Mueller
I picked up a real* European Racing header (used) from Brad last week....
Upon trying to remove the 4-into-1 collector from the primaries, I ended up cracking a weld on the inside of the collector (right at the point where all 4 tubes join)
My 1st choice is to take this collector apart (cut) and fix the welds, but I am worried that the material has been changed from use and will be "dirty" and the new welds will not work too well.
Other options are to buy a new collector (S&S Headers-$48 bucks, Burns-$269 [ouch] or of course European Racing, but I cannot find any contact info on them)
* I said real since it seems the other one I bought is from European Motorsports in SoCal...they used to be called Eurorace.
Jeroen
Mike,
I feel your "fix it untill it's broken" pain...
Why do you think you can't reweld it?
cheers,
Jeroen
L8Apex
S&S headers for $48?! I want them! Where to find? are they of any good quality for that price? I will probably make a custom muffler for mine.
Mike: BTW, car started, but has vacuum leak. Idles at 4000rpms! haha
jonwatts
QUOTE(L8Apex @ Feb 24 2003, 05:59 PM)
L8, I think he meant he could get a replacement for his broken 4-into-1 collector for $48 from S&S.
Just my take,
Brad Roberts
This guy could fuck up a steel ball. Jesus Mike... I'll respond tomorrow with his address and telephone number. We could probably TIG it back together. OR...make you a new collector.
B
Mueller
I was trying to remove the primary tubes from the collector...there was a little rust at the slip joint and I sprayed a cr@p load of penetrant...both inside and out, upon trying to twist one of the tubes (with no luck) , I noticed that the collector was "giving" more than it should have.
Dave_Darling
Actually, it's one of those ones that cannot happen to me!! You see, you actually have to work on the car for that.... rolleyes.gif
--DD
