T wing
Jun 27 2006, 11:33 AM
I've been trying to figure it out for awhile, but here's the deal. I've done a valve adjustment, set my points and timing, put in new plugs and wires and a new cap and rotor. Car is a 72 1.7L
Known issues:
1. Compression on #2 cylider is about 115, other 3 are 130, 135 and 140.
2. When I took out the plugs, 1 and 4 were a brown sooty color, and 2 and 3 were sooty, but black.
3. gnarly exhaust leak (speaking of which, what's the recomended way to replace it? I know Jim's answer, Triad.)
lapuwali
Jun 27 2006, 11:36 AM
Carbs or FI?
T wing
Jun 27 2006, 11:39 AM
Still got the FI
Dr. Roger
Jun 27 2006, 01:26 PM
re-check your points.
typical of weak ignition.
or switch over to pertronix. which is what i did.
Joe Ricard
Jun 27 2006, 02:42 PM
Agreed on the weak ignition.
Through some fire down them cylinders. While you are at it get some Magnacor wires.
So.Cal.914
Jun 27 2006, 02:50 PM
When running does your coil run hot? Could be a sign of a diseased coil. You said
you have points and changed them, but you did not mention the condenser. A sick
or dead condenser will make your car run like sh!t.
T wing
Jun 27 2006, 05:41 PM
I've got a new condeser sitting in my bug, I'll throw that on. I've actually tried two different coils. I have a bosch blue that I thought was bad so I replaced it with a pretty cheap one, ran the same afterwards. They could both be bad though, they do get a might bit warm. If my dwell angle is right on, then my gap should be too, right?
Thack
Jun 27 2006, 06:12 PM
"If my dwell angle is right on, then my gap should be too, right?"
Nope. Check the gap too. Dwell just measures when it's closed. Gap could be any value.
