QUOTE(Brad Roberts @ Jun 27 2006, 05:12 PM)
Interesting. They are changing the direction of the "front 2 back" cable.
I think we talked about the Boxster/996 shifter already having the correct "direction".
B
The Boxster/996 tower requires the direction to be reversed as well Brad. Actually that pic of Scott's new shifter setup doesn't look all that bad now. I have no experience with it, but I can assure you the PMS/old Renegade/Cunningham shifter is a complete POS as far as I am concerned.
Andy, if you have a buddy with a machine shop and solid works that is willing to help you, have him look at the car and come up with some ideas. Always good to pick the brain of someone that makes stuff for a living. I bought the Boxster tower and cables from a Porsche wrecker in the valley for $300. I ended up not using the cables as the McMaster-Carr stuff was longer and easier for me to work with. So, I would suggest trying to sources a tower only. I see that Sharper uses a rocker arm setup for the left-right selection and was able to use the shorter Boxster cables - though I hate the ends they come with. Rod ends are much nicer to work with IMO.
If you think you like the late model tower idea... suggestions to work from:
The tower isn't gated in any way, so that shifter can flop around like a wet noodle when not attached to anything. So whether you build a cable setup for a 915 or 930, they would be identical as the trans will drive the motion at the shifter. Hmm, not clear - what I mean is it doesn't matter where R is, or where 1st is, the end assembly will be identical between the 915/930.
You will need to make a bracket that you bolt to the back of the tower to mount the cable ends into. Use 5/16" cables as the quick-disconnect in that size is a perfect fit for the ball on the end of the shifter. You can drill and just screw into the plastic arm of the other one with a 5/16" fine-thread bolt.
At the rear, you will need a to make brackets to mount which shouldn't be an issue for a machinist. Either at the tower or at the rear, you need to reverse the fore-aft motion or the H-pattern would be upside down.
If you get a shifter for say $150, you could have the whole thing built (assuming friend's labor is free so just paying for cables, ends and metal) for $500 tops. Here are some photos of some of my stuff I made. I am going to build an even slicker "reversing" arm for the tube car that will be fully adjustable to set the shift pattern perfectly to what I like. 930s (and 915s IIRC) are notchy bastardos.
Shifter in car - notice my aluminum L-channel off the back to attach McM-C cables
Click to view attachmentAnd the parts I drew up in ProE to work from - these mount to the trans output shaft with the stock 8mm taper pin. Just suggestion - feel free to make up your own ideas working with your buddy. I use a 1/2" stud to "guide" that long "orange" arm fore-aft and stop it from pivoting loosely. You gotta see it in real life or really look at your own car to probably get what it going on.
My car shifted AWESOME. Notchy as f@#k, but that is the 930. I NEVER missed a shift or found myself wondering where 2nd gear was with this setup. And I could tune the exact pattern I like unlike all those other prefab deal-eos.
Click to view attachmentThat is just for reference. The yellow arm and silver extension are no more (I had to add a spacer and arm so the two cables wouldn't bind - my new design won't have that).
Shitty but hopefully helpful shot at the rear while under construction.
