QUOTE(Dan (Almaden Valley) @ Jul 11 2006, 05:54 PM)
JP the problem is that the folks desingning our courses have not read the rule book and don't know the minimum standards. Every AX I go to I end up pacing off many areas and widening them to at least the minimum...did it at least a dozen or more times last weekend.
As you say...it is the minimum and does not say anything about a maximum...
I remember a gate at a specific AX a couple years ago that 914s and narrow body 911s could go thru but all the other newer, wider, cars had to negotiate around....yielding a higher time for those newer cars. Someone did not read the rules when setting up that course.
the one that gets me is the lining of the course with chalk or using the terrain, and then placing cones to line the course. The cones are to be placed outside of the chalk or terrain boundries.
I don't see this as a sea of cones but to use the cones as markers denoting direction changes, apexes, or walls to slow folks down.
OK Dan now I need your expert help.
If I look at the SCCA book it shows the lines intersecting the cones. If you read (page 47 of 121) of the SCCA book it says lines should not be so far outside the cones as to not be visable, when someone is lining outside the cones.
It also says that the lining of the course shouldn't overlap the correct line, as open wheel drivers will tell you right away.
So it sounds optional, but it doesn't ever say to line inside the cones..
