JeffBowlsby
Jul 13 2006, 01:29 PM
So I was looking at this photo and thinking to myself...is it really dumb idea or is it the perfect solution, to install a battery support and tray with sheet metal screws or rivets? Stainless steel fasteners obviously.
I figure that not only does it save me the trouble of welding, it would be possible to prepaint the parts completely before install for better corrosion protection and they would be removable for future maintenance if necssary. I am certain that properly sized rivets or screws would be strong enough.
Anyone used screws or rivets on this before?
Brad Roberts
Jul 13 2006, 01:39 PM
Weld. All the rest will come out with vibration.
Did you buy a badge?
B
Brad Roberts
Jul 13 2006, 01:41 PM
The tray to the wall could be bolted, but the lower portion would have to go into the fram rail. This is were the real support begins. You would have to nutsert the frame rail in 6 spots.
Weld it. It lasted for at least 25+ years the first time?
B
Jul 13 2006, 01:45 PM
QUOTE(Brad Roberts @ Jul 13 2006, 12:39 PM)
Weld
if you're concerned about the welds rusting, weld the bottom part first, then spray some metal ready + primer + real paint, then weld the top part. you can primer that beforehand as well.
even welded on, the top part has enough flex so that you can lift it up to paint the underside ...
i did mine 3 years ago, no rust on it at all, and the car is parked outside with no rain tray ...
Andy
914werke
Jul 13 2006, 01:49 PM
Tried the rivits ....
Brads rights held doe a yr or two but eventually vibration took its toll.
MartyYeoman
Jul 13 2006, 01:58 PM
My tray is screwed to an angle that is in turn screwed to the wall.
The tray has a support structure that rests on the crurved surface below.
The lower contact points are rubber snubbed. I've had this setup for about
five years now and never had any problems with unexpected detachments.
It's nice to have it removable and maintainable.
watsonrx13
Jul 13 2006, 02:28 PM
Weld it.... If it was good enough for the factory, it's good enough for me....
Click to view attachment-- Rob
bernbomb914
Jul 13 2006, 02:56 PM
Weld it mine was loose when I got home from portland and might be the reason it did not run good.
Bernie
GWN7
Jul 13 2006, 03:20 PM
The only way I can think of mounting it to be removable is to weld studs in and then nut and lockwashers to hold it in place. Easier to do what everyone above has said
McMark
Jul 13 2006, 03:39 PM
with Bruce. If you want to make it removable I would weld studs/nuts to the chassis so that it could be bolted into place with blue locktite.
reverie
Jul 13 2006, 06:15 PM
Just make sure that it's welded at the right height. A local shop recently welded mine ~1" too high (which meant the engine lid couldn't be closed due to the rain tray), so the whole battery tray and support had to come out again and be re-welded.
Cap'n Krusty
Jul 13 2006, 06:36 PM
QUOTE(reverie @ Jul 13 2006, 05:15 PM)
It's a bit difficult to understand how that could be done, what with the parts fitting right into place and all ................... The Cap'n
Brad Roberts
Jul 13 2006, 06:38 PM
That is wierd. The wall has a HUMP in it just for the tray to weld too. I have NO idea how they could have messed that up?? WTF??
B
McMark
Jul 13 2006, 06:58 PM
I know my new marketing push!
Original Customs - Where we weld in your battery tray
right.
WildBill
Jul 13 2006, 07:38 PM
Not really what you asked but I would move it to the front trunk. Helps with handling/rust and you could always weld the tray in and move it later to make it look "correct".
JeffBowlsby
Jul 13 2006, 08:17 PM
Naw...I am waiting for the LE edition....
Welding it is, thanks for the insight. I hoped someone had tried to rivet/screw it before, glad I asked. Mark, you need to open a south bay shop so I can hire you to weld in my tray...
Hey thats it Mark...you doanneed no stinkin brickNmortar shop...do mobile 914 work...your shop truck could be a 914 modified for hauling parts/toolz...
