Mine is slowly coming together this Summer, the body is getting ready for paint and I should have my rebuilt engine within a week. I went over board and will have an immensely powerful engine with the displacement of the early 935's, 3.16 liters, twin-plugged, 86 930 intake with a Euro fuel distributor, K27 turbo with the large 3.0 SC heads and SC cams. I ask myself why everyday....
IAMCHAPPYS PORSCHE 914 6 GT TURBO CARERRA BUILD SHEET
IMSA SPEC. 3.16 CIS Turbo Twin-plug engine
Using 1979 SC 3.0 block, crank. rods and heads
1991 3.3 turbo pistons and cylinders
Rod pin modification for stroke
K27 7200
Spearco 1080 cfm intercooler
Two 7" electric fans for intercooler
Transmission cooler
Tilton electric transmission cooler pump
Mark Donahue special edition steering wheel(very rare).
Terry cables
86 930 turbo intake manifold
Bosch 400 lph racing fuel pump
Tial 38mm wastgate
Tial 50mm BOV
Turbo x boost controller
Hobbs 4 lb pressure switch
7th fuel injector micro fueler (911sc CSV)
Supertech 12 plug conversion distributor
MSD boost retard ignition with rev control
MSD shift light
2 MSD Blaster 2 coils
Magnacore twin plug 12 wires
RSR plug holders
Maganaflow 2.5"in 2.5"out muffler
Custom stainless crossover pipe
Hooker resonator exhaust tip
930 cam driven oil pump
Aeropquip stainless and blue line socketless fuel and oil lines
Fire sleeve
Front mounted oilcooler
Factory 914-6 oil tank
Factory 914-6 engine mount
Factory 914-6 rear stub axles
Front mounted oil cooler
911 front end with aluminum crossmember
951 Turbo brakes calipers front and rear
Brake bias valve
Carrera solid rotors
Speed bleeders
Porterfield RS-4 brake Pads
23MM master cylinder
Adjustable front swaybar
Rear sway bar (unmounted) for street
Set of 7,8X16 phone dial wheels
Set of 7,8x16 Fuchs (951)
Yokohama es100 225/50/16 , 245/45/16
Toyo RA1 225/50/16 , 245/45/16
Adjustable Koni shocks in front
911 gauges
901 side shift trans with Quaife and short gears (M,S,Z)
901 side shift trans stock gearing
Kennedy stage 2 clutch and pressure plate with starter ring
Shorten shifter
914-6 aluminum plated headers
Rear end has been reinforced
Suspension ears reinforced
Interior long reinforced
Bilstien shocks adjustable perches in rear
200lbs springs
Turbo tie rods
Steering rack has been lowered for bump steer
camber truss front and rear
Autopower Full roll cage
2005 Alpine cd mp3 player with 8" Quart subs driven by Alpine T220, Alpine type R 5 1/4 door and 6.5 kick panel speakers driven by Alpine T240 amp.
LED blue gauge bulbs
Gauge trim rings
Halogen headlights.
Gtech computer
a/r before turbo analog gauge Westberg
vdo boost vacuum gauge
gauge pod
Optima yellow deep cell battery
Billet battery holder
Oil dump tank
993 spare tire cover and tool kit
Hood mounted fuel door
GT fiberglass flares, rockers, Custom 914 6 GT valance and rear spoiler with intercooler duct.
Aluminum floor board
Aluminum pedals
All new chrome trim items
New engine lid letters
New ghost reflector rear lense
New windshield
Tow hooks
Modified Gt valance with brake ducts
914 Club badge ( on order )
