Where are the Porsche 6 turbos? |
3.6 teener |
Jul 25 2006, 05:00 PM
Newbie Group: Members Posts: 24 Joined: 10-January 06 From: San Diego, Ca. Member No.: 5,400 |
So I've been lurking, reading the posts, and 1dering... where are the Porsche 6 turbo conversions? Got information, pros or cons, pics? Would love to spit some waste gate flames out the back of mine!
Andyrew |
Jul 25 2006, 05:37 PM
IMCHAPPY has one... and theres one race car that I know of... Thats about it...
Not many guys feel they "need" 500hp.. im one of those needy guys I guess.. |
iamchappy |
Jul 25 2006, 08:18 PM
Mine is slowly coming together this Summer, the body is getting ready for paint and I should have my rebuilt engine within a week. I went over board and will have an immensely powerful engine with the displacement of the early 935's, 3.16 liters, twin-plugged, 86 930 intake with a Euro fuel distributor, K27 turbo with the large 3.0 SC heads and SC cams. I ask myself why everyday.... (IMG:style_emoticons/default/sad.gif)
IAMCHAPPYS PORSCHE 914 6 GT TURBO CARERRA BUILD SHEET IMSA SPEC. 3.16 CIS Turbo Twin-plug engine Using 1979 SC 3.0 block, crank. rods and heads 1991 3.3 turbo pistons and cylinders Rod pin modification for stroke K27 7200 Spearco 1080 cfm intercooler Two 7" electric fans for intercooler Transmission cooler Tilton electric transmission cooler pump Mark Donahue special edition steering wheel(very rare). Terry cables 86 930 turbo intake manifold Euro fuel distributor Bosch 400 lph racing fuel pump Tial 38mm wastgate Tial 50mm BOV Turbo x boost controller Hobbs 4 lb pressure switch 7th fuel injector micro fueler (911sc CSV) Supertech 12 plug conversion distributor MSD boost retard ignition with rev control MSD shift light 2 MSD Blaster 2 coils Magnacore twin plug 12 wires RSR plug holders Maganaflow 2.5"in 2.5"out muffler Custom stainless crossover pipe Hooker resonator exhaust tip 930 cam driven oil pump Aeropquip stainless and blue line socketless fuel and oil lines Fire sleeve Front mounted oilcooler Factory 914-6 oil tank Factory 914-6 engine mount Factory 914-6 rear stub axles Front mounted oil cooler 911 front end with aluminum crossmember 951 Turbo brakes calipers front and rear Brake bias valve Carrera solid rotors Speed bleeders Porterfield RS-4 brake Pads 23MM master cylinder Adjustable front swaybar Rear sway bar (unmounted) for street Set of 7,8X16 phone dial wheels Set of 7,8x16 Fuchs (951) Yokohama es100 225/50/16 , 245/45/16 Toyo RA1 225/50/16 , 245/45/16 Adjustable Koni shocks in front 911 gauges 901 side shift trans with Quaife and short gears (M,S,Z) 901 side shift trans stock gearing Kennedy stage 2 clutch and pressure plate with starter ring Shorten shifter 914-6 aluminum plated headers Rear end has been reinforced Suspension ears reinforced Interior long reinforced Bilstien shocks adjustable perches in rear 200lbs springs Turbo tie rods Steering rack has been lowered for bump steer camber truss front and rear Autopower Full roll cage 2005 Alpine cd mp3 player with 8" Quart subs driven by Alpine T220, Alpine type R 5 1/4 door and 6.5 kick panel speakers driven by Alpine T240 amp. LED blue gauge bulbs Gauge trim rings Halogen headlights. Gtech computer a/r before turbo analog gauge Westberg vdo boost vacuum gauge gauge pod Optima yellow deep cell battery Billet battery holder Oil dump tank 993 spare tire cover and tool kit Hood mounted fuel door GT fiberglass flares, rockers, Custom 914 6 GT valance and rear spoiler with intercooler duct. Aluminum floor board Aluminum pedals All new chrome trim items New engine lid letters New ghost reflector rear lense New windshield Tow hooks Modified Gt valance with brake ducts 914 Club badge ( on order ) Attached image(s) |
Sammy |
Jul 25 2006, 08:32 PM
. Group: Members Posts: 1,190 Joined: 21-January 03 From: Orange, Ca Member No.: 178 |
You can't turbo a 914 (IMG:style_emoticons/default/bs.gif) (IMG:style_emoticons/default/dead horse.gif) (IMG:style_emoticons/default/chair.gif) (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/rocking nana.gif) (IMG:style_emoticons/default/poke.gif)
turboman808 |
Jul 25 2006, 08:34 PM
Advanced Member Group: Members Posts: 2,718 Joined: 31-January 06 From: North Jersey Member No.: 5,505 Region Association: North East States |
I called the engine builder of my car. Said the motor couldn't be turboed. To bad this car would be absolutely sick with 100 more hp.
iamchappy |
Jul 25 2006, 08:38 PM
Sammy your the one guy who I know would love to get in this car with me and go.
You have been with me through out this endeavor. Just think of the money I must of spent, no, lets not think, I would like to sleep tonight. The scary part is there is still a lot more on the wish list. The engine should be putting out 400hp to the wheels which is way more than I need. |
Mueller |
Jul 25 2006, 08:39 PM
I called the engine builder of my car. Said the motor couldn't be turboed. To bad this car would be absolutely sick with 100 more hp. just lower the compression, it cannot cost "that" much more compared to the rest of the costs associated with adding a turbo.......the only other thing that would make your motor unsuitable would be the cams, but those too can be changed (IMG:style_emoticons/default/smash.gif) Look for some threads by Maltese Falcon, he has a turbo /6 with 935(?) horizontal fan (IMG:style_emoticons/default/burnout.gif) |
iamchappy |
Jul 25 2006, 08:45 PM
Maltese has about 600 hp, way sicker than I.
Aaron Cox |
Jul 25 2006, 09:46 PM
cha.. marty has a fatty 935 fan (horizontal down draft fan) and bi-turbo setup....
insane |
banksyinoz |
Jul 26 2006, 01:13 AM
finally getting back into it Group: Members Posts: 223 Joined: 17-June 05 From: queensland, aus Member No.: 4,293 Region Association: Australia and New Zealand |
[ Just think of the money I must of spent, no, lets not think, I would like to sleep tonight.
The scary part is there is still a lot more on the wish list. The engine should be putting out 400hp to the wheels which is way more than I need. [/quote] (IMG:style_emoticons/default/pray.gif) holy (IMG:style_emoticons/default/stromberg.gif) batman wat u do morgage the house that parts list would be like 10 xmas prezzies in one (IMG:style_emoticons/default/happy11.gif) (IMG:style_emoticons/default/happy11.gif) (IMG:style_emoticons/default/happy11.gif) (IMG:style_emoticons/default/biggrin.gif) |
TimT |
Jul 26 2006, 03:40 AM
We had a customer that wanted us to turbo his stock 3.6. He didnt want us to change the compression ratio or tear down the engine at all.. just turboo charge it.
so we made manifolds. and got some tiny K26s, and limited the boost to 4-5 psi AFAIK the car is still on the road.. The customer moved to Florida soon after we finished his car. BTW it was a 911, just illustrating that high compression engine can be turbocharged |
Sammy |
Jul 26 2006, 08:25 AM
Chappy, I would love to ride in your car. In fact I've thought about it several times.
Turboman, if your engine builder said the engine could not be turbocharged he does not know what he is talking about. Any internal combustion engine can be turbocharged. Some can run high boost levels safely, some cannot. It probably does not make sense to turbocharge an engine that could only handle 1 psi of boost safely, but it still could be done. That might have been what he meant, that it wasn't worth it because the safe boost level was low. What kind of engine are you running? My stock 3 liter six is turbocharged and I'm running 7 psi boost which is good for around 80 or 90 additional hp. |
Aaron Cox |
Jul 26 2006, 10:34 AM
Chappy, I would love to ride in your car. In fact I've thought about it several times. Turboman, if your engine builder said the engine could not be turbocharged he does not know what he is talking about. Any internal combustion engine can be turbocharged. Some can run high boost levels safely, some cannot. It probably does not make sense to turbocharge an engine that could only handle 1 psi of boost safely, but it still could be done. That might have been what he meant, that it wasn't worth it because the safe boost level was low. What kind of engine are you running? My stock 3 liter six is turbocharged and I'm running 7 psi boost which is good for around 80 or 90 additional hp. and to add more difficulty to turboman's setup... he has ITB's (IMG:style_emoticons/default/smile.gif) |
Mueller |
Jul 26 2006, 11:04 AM
and to add more difficulty to turboman's setup... he has ITB's (IMG:style_emoticons/default/smile.gif) that is a minor detail, an air box can feed the throttle boxes..... i'm guessing the engine builder is just playing it safe, if turboman adds a turbo and launches the motor as it is, the engine builder does not want to take any flack for something that was not his fault.... |
iamchappy |
Jul 26 2006, 12:51 PM
I built mine for reliablity using 3.3 turbo piston and cylinders, twin plug, turbo oil pump, lower compression and extra fuel enrichment, Supertec head studs, ARP rod bolts with 928 nuts and racing valve springs, intercooler.
As long as I was going through the trouble and expense I felt every precaution needed to be taken. My weak link is the transmission, since this is a daily driver and if i remain cautious and shift smoothly, things should hold together until I venture into the transmission upgrade down the road. |
grantsfo |
Jul 26 2006, 01:06 PM
Arrrrhhhh! Group: Members Posts: 4,327 Joined: 16-March 03 Member No.: 433 Region Association: None |
You can't turbo a 914 (IMG:style_emoticons/default/bs.gif) (IMG:style_emoticons/default/dead horse.gif) (IMG:style_emoticons/default/chair.gif) (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/rocking nana.gif) (IMG:style_emoticons/default/poke.gif) A 914-6 isnt a 914 it's a Porsche. (IMG:style_emoticons/default/biggrin.gif) ...You can turbo a Porsche. |
sww914 |
Jul 26 2006, 01:51 PM
I think if you turbo a type IV, you should wear a flak jacket when you drive the car.
nein14 |
Jul 26 2006, 02:27 PM
Senior Member Group: Members Posts: 838 Joined: 6-February 03 From: USA Member No.: 262 |
turboman808 |
Jul 26 2006, 02:50 PM
2.7 rs I read awhile back and it seemed porsche had trouble turboing these as well.
I would have to check the compression for myself. I have been told 10:1 and 8:1 (IMG:style_emoticons/default/confused24.gif) Yeah I got ITB but it is fuel injected so making pipes running to the ITBs might look kinda cool. Probably wouldn't do it though. I'm saving for my pantera (IMG:style_emoticons/default/driving.gif) Besides lets be honest here. That kinda power is only good for showing off |
Sammy |
Jul 26 2006, 02:52 PM
sww914, I'm not sure what your post means but I "think" you're suggesting that a turbocharged type 4 isn't reliable and will blow up.
My personal experience as well as several others on this board suggest otherwise. I can tell you of 3 or 4 people who have turbocharged type 4 engines with no problems, can anyone name one single person who has had a turbocharged type 4 engine blow up? If so it was probably because they got greedy and cranked the boost up waaay to far. I ran a turbocharged 2 liter for about 2 years and then sold it to a guy who used it as a daily driver for a while before selling it to someone else. No blow up, no problems. It didn't even get to sit on jackstands, so based on that a turbocharged 914 is more reliable than a non-turbocharged 914 (IMG:style_emoticons/default/wink.gif) |
Lo-Fi Version | Time is now: 16th May 2024 - 08:15 PM |
