QUOTE(Aaron Cox @ Aug 6 2006, 10:17 AM)
OK....
strut housings. 3 (4 really) kinds of housings.
A ) Boge. Black. 3" or 3.5" Spacing. Early vs Late respectively. available in both wedge pin, and thru bolt style ball joints. Strut inserts available are, boge, bilstein, koni, mulholland, Kyb, and more.... (MOST COMMON HOUSING)
B ) Bilstein. Green. 3" or 3.5" Spacing. ONLY inserts that fit are Bilsteins DESIGNED for bilstein HOUSINGS. Sport or HD available.
C) Koni housing - 3.5" only i believe. both early and late ball joint styles. only inserts that fit are KONI for KONI housings.....
what color are yours?
Aaron,
The color of the housing is black, the ball joints are held in via wedge pin.
Aaron, I have red/orange koni shocks, they would be considered Street correct and would be softer than the koni yellow?
