Full Version: Practicing for RRC Caravan
Aaron Cox
nice view of riverslime....
what happened?
Toast
Heading to jsharp.gif on the 91 fwy, and suddenly I had no more excelleration, like I ran out of gas.
Luckily I was by the Tyler mall exit, so I costed off and parked in the mall. An oriental chick in sandals helped me push the 914 the rest of the way into the parking lot. tongue.gif
Still had power. Looked in the tank...there was gas. But wouldn't start. dry.gif
Aaron Cox
pinched fuel line? clogged fuel filter? vapor lock?
are the injectors spraying fuel? can you smell gas??
all you need is air.fuel.spark.
verify which ones you have, and lets work from there
Toast
No spark
Aaron Cox
tell us about your ignition setup.
check all grounds etc?
points? optical crane? pertronix? compufire?
Toast
Changed to points when the Crane Electronic Ignition failed at the last RRC (that was the final problmatic solution by the way).
All grounds check.
Changing battery terminal. Broken by bolt.
Brando
Your battery terminal broke? Ouch... That might cause probs.
If you're changing batteries, go with an optima red top, or grab one of those orbital brand gel-cell batteries at kragen. Best $80 I spent smile.gif
GWN7
I think she means the terminal end clamp bolt broke.....no clamp, no full power for starts. smile.gif
Toast
Ok, changed battery terminal (not post Brandon rolleyes.gif ) to new. Still wont start.
Brando
Oops, got your reply in just before mine...
Fuel pump working, getting spark... It should run then. That means your injectors aren't firing or your timing is WAAAAY off. But I think the former, not the latter.
Now's a good time to test your CHT. Got an Ω meter handy?
GWN7
Spark? Coil could have shorted cause of lack of power.....
Toast
Toast
QUOTE(GWN7 @ Aug 6 2006, 11:12 AM) *
GWN7
Brando
Points!
Check 'em before you wreck 'em.
Break out your business card and get ready to set 'em. If you still aint got this troubleshotted all out by 4:45 I'll head to Ron's and attempt to help (and not break anything more).
I suggest you walk down the street and buy two sets of Bosch points. Put one in your glove box, intall the other smile.gif
Toast
Right on Dude. Here is the guilty culprit:
Toast
Can you tell?
Joe Bob
Can you open them up by hand??? They COULD be welded shut.
BTW...the chick in sandals????
Toast
Yea, I could open them by hand (look closely at the second pic).
Sorry, not pics. Was too busy pushin the teener. But she did have very long hair, and cheep sun glasses. Slightly on the 'healthy' side.
JoeSharp
Yep, it's completly gone.
:PERMJAGRIN: Joe
TonyAKAVW
I've got a very low mileage Pertronix module that I don't need anymore. It has maybe a year's worth of driving on it. Need to find the rotor that goes with it. gotta be in a box somewhere.
-Tony
Brando
Tony... If toasty doesn't claim that freebie I sure will... I got a spare rotor around here somewheres... smile.gif
Toast
Brando
I gots a spare rotor for that. When ya want it?
JoeSharp
Brandon: Bring it to the A/X.
Tony, are you coming to the A/X?
:PERMAGRINM: Joe
