vortrex
Mar 3 2003, 12:56 PM
say one was to buy a stock /6 car and wanted to enhance the driving experience with some more HP, yet still keep the car "numbers matching". what can you do to the stock 2.0? I imagine 2.2S, what about other configs? what does going to these larger displacements and S specs entail?
Mueller
Mar 3 2003, 01:24 PM
do what a lot of original /6 owners do:
yank out the 2.0 motor and stick it in the garage for later use, put a bigger motor such as a 3.0 in it's place
A guy around the corner from me with an original /6 did the 2.2S upgrade...fun car to drive (my first drive in an original 6 many years ago)
Get Bruce Andersons
911 Performance Handbook, it's a
must read for anyone thinking of purchasing a vehicle powered by a Porsche flat 6.
Red-Beard
Mar 3 2003, 01:36 PM
My car has been upgraded to a 2.2 with S Cam, but still running the original heads...I'm guessing that it produces about 160 hp at the high end. And that is plenty!
There is a guy on the Pelican list who is running a "2.5" which is the 2.0 cut to take the 2.7 P&Cs but maintaining the original stroke. I am sure some work was done to get the compression ratio into the correct region.
James
campbellcj
Mar 3 2003, 01:57 PM
My car will also have a factory -6 built to 2.2S specs shortly. We are not sure yet whether any head work was done or if it still has the "T" ports. Also need to check if it has a counterweighted crank or not. I'll be running headers and open pipes, Weber 40's and either a Bosch CDI or MSD ignition. It should be a nice match for my car.
J P Stein
Like Mueller said, yank it.
Unlike Red Beard said, 160 hp is not plenty, tho better than 110.
vortrex
Mar 3 2003, 02:14 PM
what has to be done to get a 2.2S? new P&C and S cam? case stays unmodified?
anyone know anything about the white 914-6 2.5 car that's on the SD PCA page for sale?
EDIT: nevermind about the car in SD, it's not there anymore.
TimT
Mar 3 2003, 03:50 PM
The 914 i just bought has a 3.2 stuffed in it, supposedly 260 hp.
I am also building a 2.2 race motor for my 911
You can get as much as 230 hp from a 2.2. It will cost you a fortune though
( ask how I know)
The heads will need to be improved. open the heads up to 36mm, better yet 38mm (the 911/22 had 38mm heads and made 230 hp). Twin plugging would be recommended to.
You should get a S cam, better yet a GE-80
while the case is apart perform the case mods, and shuffle pin. replace the oil pump with a bigger one ( turbo or 964 type)
The crank should be replaced with a S crank. Ive heard of some pretty rad engines that were built on a T crank though.
Its way more economical to buy a 3.0 or a 3.2 than to build a potent 2.2 Parts and machining add up quickly
campbellcj
Mar 4 2003, 12:14 AM
TimT is dead on...the factory built some real screamer 2.0 and 2.2 engines back in the day; >220hp. But who knows how long they lived and they were probably a pretty long stretch from the regular production builds. $$$$$
My 2.2 is intended as a trainer; it will either be sold along with the car when I'm ready to move up, or the engine will be passed on to the next addict and replaced with a 3.0 or 3.2 I am running in a 'spec' (restricted) race class and can't afford the modification points to do port work, EFI or twin-plug on the 2.2. I am however already taking mod points for the S cams and higher compression, so I could go even more aggressive in those areas if I wanted to (although the $/hp is way ugly when you're talking 911 race pistons and cams). I could also potentially run Weber 46's instead of 40's but probably no point unless the breathing is opened up.
I'm just sick of listening to this VW racket behind my head...can't wait to get the sixer fired up back there
olav
Mar 4 2003, 12:21 AM
I kept my original 2 liter and put in a 3.2 and it is perfect. Nice sound and I can keep up with the Boxster S's now.
I have carbs on it so it looks stock though.
ChrisReale
Mar 4 2003, 09:58 PM
QUOTE(campbellcj @ Mar 3 2003, 10:14 PM)
Hey, my car takes offence to that
You telling us that you dont like the tappet noise? Its musical when you go fast... :cursor:
vortrex
Mar 4 2003, 11:29 PM
yes, olav has the dream car and in the right color too.
was merely asking because I am leaving SF for the east. thinking about taking or importing a /6 at some point as compensation for my soon to be misery. 3.2 sounds great, but I also have a thing for vintage, such as 2.2S. it's got to be more fun than the 2.0 and probably not as expensive as the 3.2 (no motor to store either...).
ChrisReale
Mar 4 2003, 11:33 PM
Where are you moving to?
campbellcj
Mar 4 2003, 11:39 PM
QUOTE(ChrisReale @ Mar 4 2003, 07:58 PM)
Hmmm. Honestly, to me the Type4 sounds like a lawn tractor on steroids -- and I'm not sure that's a "good thing". Sorry, but after owning an early 911 (2.2E w/ MFI) for 12 years, the comparison between the two flavors of engines is etched pretty deeply in my mind.
I do like the torque curve of the 914/4 powerplants though
ChrisReale
Mar 4 2003, 11:42 PM
Im just messing with you Campbell
. You should have heard my 914 when it had an exhaust leak. Sounded like my neighbors Bus, but louder.
vortrex
Mar 4 2003, 11:43 PM
off to philadelphia! just got a job today. been 14 months out of work.
vortrex,
Congrats(!) on the job. Meuller's right. Get BA's book and read it. Most of the P-6 mysteries and alternatives are covered in a pretty easy read. Chris is right. The 6 sound kills. (but if truth be known, you have to add a turbo to get the spine chill :-)
kim.
vortrex
Mar 5 2003, 01:13 AM
yeah I am gonna get that book, been meaning to for a long while now. wonder what it costs to have a 2.0 converted to 2.2S?
vortrex: cost? dunno. Someone else will chime in I'm sure. P-6's seem to have nothing cheap about them tho. (i.e. price barrels/pistons at the popular P sites -- you'll know what I'm talking about) Actually, you can prolly do this without BA's book, in that I'm guessing that most sites make assumptions about what case you are using when they quote.
(I was able to scope out barrel/piston costs for my last rebuild, before I had to actually shell out the cash. Good thing too!)
I've not done the path you're following so I don't have BTDT (although it may happen in the next couple years so I'm looking for your BTDT!)
kim.
JmuRiz
Mar 5 2003, 09:34 AM
I got to see a wild 2.2 motor this weekend first hand. It was a thing of beauty. It's the race motor of one of my shops' mechanics. Here are some of the details. Has a 46 carbs, 316 cam
sweet fan shourd (looks like the old 914 shroud color) and 906 intake manifolds...that's right real 906 magnesium manifolds. Makes some 230hp at 8500 RPM. All I could do was dream of this in my 914...drool
Nathan
campbellcj
Mar 5 2003, 10:48 AM
To truly convert a 2.0T to 2.2S specs would be prohibitively expensive: barrels & pistons, cams, head work (open up the ports), and crankshaft. Plus of course the S cars had MFI vs. Webers but most guys can "live" with that OK; in fact I have to run carbs to stay in my POC class. You get creamed (points wise) for induction system swaps.
Even just doing the S barrels & pistons and cams is horrendously expensive; prolly $4K just for parts I'm guessing ?
fuch toy
Mar 5 2003, 11:43 AM
Yank it, mothball it and put in a 3.0-3.6.....you will never look back.
jtf914
Mar 5 2003, 12:25 PM
What is the "cleanest" (cheapest/easiest) engine to use for a 6 swap? If I wanted to stay with my current ignition system, fuel delivery, and oil cooler, what are my options (if any)?
We beat the 4-6 conversion to death, but what considerations have to be made when swapping 6-6? I know I'm going to need a conversion flywheel (3.0 or 3.2), but what else?
Would I be looking at a cam change in order to stay with webers, or are the stock cams OK?
Can I run a 3.0-3.2 without a front oil cooler (JP and Brad, feel free to fight this one out)?
Olav, what was changed on your car?
I'm not a CW, but I wouldn't want to make changes that can't be easily reversed.
Jeroen
Mar 5 2003, 02:26 PM
Don't know the exact details (so get BA's book!!!) but I believe the 2.0 differs from later engines (2.2 and on) on the oil galleries/squirters...
cheers,
Jeroen
fuch toy
Mar 5 2003, 03:18 PM
My 3.0 needed more cooling than the internal cooler could give it. The 3.2 probably the same. The 3.6 HAS NO internal cooler.
TimT
Mar 5 2003, 03:25 PM
I did the 2.0T to 2.2S+ improvement in my 69 911 (I call it a plus because I did the oil mods, installed squirters, and installed a 930 oil pump) I did every upgrade and improvement to the engine and then some.
I havent added the receipts up, and dont really want to
I did all the assembly work myself, so the only costs were parts , machining, and shipping (shipping the various parts to be machined adds up) Of the top of my head Ill bet I spent about $9000 so far.
Im hoping to get between 200 and 210 HP out of this engine.
Are there cheaper ways to get more power? hell yea!!! 3.0 short block @ $3000, a 3.2 is about $5000 im guessing.
But I will have a 8000 rpm motor with a short gearbox in my 1850 lb 911
As others mentioned if you are going to run in vintage you need to with a 2.0 or 2.2. The 3.2 will knock you in to some very quick classes.
vortrex
Mar 5 2003, 04:11 PM
geeez $9k and you did all the work? sounds like a hot motor though. maybe a 3.2 is not such a bad thing aferall.
heck, I better work on getting a garage and a car first!
jockellis
Feb 25 2020, 12:15 PM
Porsche had the 914-6 re-homologated to a 2.5 because -6 racers were whining about not being able to keep up with the bigger engines 911s, according to lawyer and ex-Porsche racer David McLain.
Root_Werks
Feb 25 2020, 12:18 PM
Good Lord, that last post complained about a $9k engine swap. That MUST have been 17 years ago.
ClayPerrine
Feb 25 2020, 12:20 PM
WOW! 17 year old zombie thread!
porschetub
Feb 25 2020, 05:39 PM
times have changed somewhat
