QUOTE(Rand @ Sep 12 2006, 11:40 PM)
Dude, sorry for the semantic confusion. But when I heard "seam sealer" I was thinking of the more common seam sealer used between body panels.
You are talking engine parts, which is a different matter. And now let us address a whole new series of opinions!
Ok, some of my opinions on this...
Pushrod tube seals: Loctite 565 flexible sealant. Rotate the tubes and let them set. I think Jake will back this.
Case halves and jugs? Not sure you need chemical junk there, but I will defer to the engine gurus on those.
Intake runner gaskets? Nothing crazy needed there. I used a cheap solution: Radiator hose pieces that match the dimensions. They are nice and tight. The purists will insist on cloth-covered pieces.
Exhuast rings? If you mean the copper gaskets between the heads and headers/exhuaust pipes/manifolds, then just get them from a local VW supplier. Cost is not an issue.
Best of luck!
ok so for push tubes i need a flexible sealer huh?
i heard that the 6-ers use loctite 574 for the case
for the intake runners i mean where the runner meets the intake port of the head.
i didnt think the exhaust needed sealer, but i had to check, over the course of buying parts for the rebuild i have accumulated 2 sets of copper exhaust gaskets.
thanks for the response
-jim
