QUOTE(fat73 @ Sep 12 2006, 11:31 PM)
QUOTE(Maltese Falcon @ Sep 12 2006, 11:22 PM)
Fat, is the OE tubo mounting canted like that ? My experiences with mounting turbos nixes anything but a straight axis mounting of the unit. The problem is seal failure at the cartridge (fan assys/ axle)) . The seals being of the ceramic, o-ring or carbon ring seal...within a short time will not be able to control the oil and start consuming it in the compressor and /or turbine housings.
Check it out.
Other than that , it's SEXY !
marty
I believe it is some. This is a Renegade mod to move the turbo down just a hair for clearance. I'll have to check my 06 Forester.
Dana...if you're out there and see this post, do you have a comment?
By the way....another pic
mine is mounted like that and has been in my daily driver for over a year, no smoke, no oil leaks, 16.5 pounds o' boost.
if you want your turbo to be straight start cutting your rear trunk!
