QUOTE(BatAc @ Sep 21 2006, 12:55 PM)
OK........I have fire..........problem.........throttle cable in rear, in engine bay......it's not hooked up correctly, but am baffled as it doesn't seem to jive as though it should.........does anyone have an image of a 74 1.8 to give me an idea how this little jigsaw puzzle works (is hooked up).........Merci........
Hi, I could not get a clear pic to send because of the camera flash. you have a 74 with D-JET? the cable that has the threaded end with the 2 nuts? if so it comes in under the air cleaner hold down plate next to the cold start valve. them up to the throttle body... Do Not over tighten the 2 lock nuts or you will break the cable end.
