Hi fellas,
I was cleaning up my technical bookmarks to send over to Aaron.
Then I thought that maybe a few of you might have some fun perusing some differant sites specific to the 914 and/or the type 4 engine, trans, etc..
There is some general High Perfomance stuff that isn't specific to the 914 included.
Also some great technical stuff on carbs (Dells & Webs), engine theory, calculators, 911 Torsion bar to spring conversion chart , wheel offset calculators, etc.
Purveyors of trick nuts and bolts, cable shifters, etc.
I left out the over the top tech stuff.
I hope this is OK to post these links.
IF NOT. Admin PLEASE delete the post.
Let me know if ya need more via PM or post.
Cheers,
Clayton
Ahnendorp Type 4 parts: http://english.ahnendorp.de/typ4-1.html
Some Kewl EDIS and Spark Plug info: http://www.not2fast.com/ignition/
Every little fastener and stuff you will ever need: http://www.mcmaster.com
Porsche fasteners and other bits: http://www.olander.com
Porsche manuals: Look at the first four at the top.
VDO gauge repair and replacement:
Physics of racing for Porsche: http://autopedia.com/stuttgart-west/StuttPhysics.html
Car set up guide: http://www.wtrscca.org/tech.htm
Dellorto carbs, tech stuff:
Type 4 Industrial engines pics. http://www.eckstein-kuebel.de/vw127.htm
L-Jet repair and trouble shooting: http://manuals.type4.org/ljet
CV Joints 101
For Gustl, 1600 car makes and pics: http://www.globalautoindex.com/makelist.plt?letter=All
911 wheel weights and sizes: http://members.rennlist.com/911pcars/WheelWts.html
More 914 manuals on line: http://www.icbm.org/erkson/personal/Porsch...nuals/index.htm
Wave tuning the intake tract for optimum performance. Nice thread:
I love speed talk: The big boys play here.
http://speedtalk.com/forum/viewtopic.php?t=1163
DIY Metal Shaping data: http://allshops.org
Isotropic metal Finishing: http://www.taylor-race.com/isotropic.cfm
Possible Power steering for a 914?: http://www.germanauto-saco.com
The REAL NARP BBS: http://16.freebb.com/narp
REAL Porsche lug nuts: http://www.boothedesign.com/boltsstudslugs.html
Turbo calculator: http://not2fast.wryday.com/turbo/glossary/turbo_calc.shtml
911 Torsion bar to coil conversion chart: http://instant-g.com/Data/911CoilConv.html
Engine Tech data: http://www.epi-eng.com/ET_TOC.htm#contents
914 cable shifter manufacturer: http://www.brandwoodcarsllc.com/mofcart/cbindex.html
Weber OEM jetting table: http://www.gracieland.org/cars/techtalk/weboem.html
Every Automotive Calculator you will ever need: http://www.wallaceracing.com/Calculators.htm
Oversteer and Understeer correction sheet and MORE!!!!:
http://rogerkrausracing.com/overundr.html
Wheel offset calculator: http://www.1010tires.com/WheelOffsetCalculator.asp
Intake Manifold Tech: Runner Size Calculations: http://www.team-integra.net/sections/artic...p?ArticleID=466
Distributor Interchange, Bosch To VW: http://www.oldvolkshome.com/ovhignbo.htm
Intake extrusions Aluminum: http://www.rossmachineracing.com/products.html
Nice gear ratio calculator: http://www.et-studios.com/motorsports/gears/gears.html
ITG filters and other cool stuff: http://coastfab.com/specials.html
Chandler Products - 12 Point Bolts: http://www.chandlerproducts.com/12point.htm
Trick Fasteners: http://www.fitfastener.com
F1 Engines Valve technology: http://scarbsf1.com/valves.html
Remmele trick Type 4 engine stuff:
http://www.remmele-motorsport.com/en/index_aircooled_en.html
If I had to use another transaxle?: http://www.theoffroadshop.com.au/services_gearbox_ren.htm
