Some Interesting links for you Technical guys., Mostly tech links specific to air cooled & racing |
Twystd1 |
Sep 24 2006, 06:20 AM
Hi fellas,
I was cleaning up my technical bookmarks to send over to Aaron. Then I thought that maybe a few of you might have some fun perusing some differant sites specific to the 914 and/or the type 4 engine, trans, etc.. There is some general High Perfomance stuff that isn't specific to the 914 included. Also some great technical stuff on carbs (Dells & Webs), engine theory, calculators, 911 Torsion bar to spring conversion chart , wheel offset calculators, etc. Purveyors of trick nuts and bolts, cable shifters, etc. I left out the over the top tech stuff. I hope this is OK to post these links. IF NOT. Admin PLEASE delete the post. Let me know if ya need more via PM or post. Cheers, Clayton Ahnendorp Type 4 parts: http://english.ahnendorp.de/typ4-1.html Some Kewl EDIS and Spark Plug info: http://www.not2fast.com/ignition/ Every little fastener and stuff you will ever need: http://www.mcmaster.com Porsche fasteners and other bits: http://www.olander.com Porsche manuals: Look at the first four at the top. VDO gauge repair and replacement: Physics of racing for Porsche: http://autopedia.com/stuttgart-west/StuttPhysics.html Car set up guide: http://www.wtrscca.org/tech.htm Dellorto carbs, tech stuff: Type 4 Industrial engines pics. http://www.eckstein-kuebel.de/vw127.htm L-Jet repair and trouble shooting: http://manuals.type4.org/ljet CV Joints 101 For Gustl, 1600 car makes and pics: http://www.globalautoindex.com/makelist.plt?letter=All 911 wheel weights and sizes: http://members.rennlist.com/911pcars/WheelWts.html More 914 manuals on line: http://www.icbm.org/erkson/personal/Porsch...nuals/index.htm Wave tuning the intake tract for optimum performance. Nice thread: I love speed talk: The big boys play here. http://speedtalk.com/forum/viewtopic.php?t=1163 DIY Metal Shaping data: http://allshops.org Isotropic metal Finishing: http://www.taylor-race.com/isotropic.cfm Possible Power steering for a 914?: http://www.germanauto-saco.com The REAL NARP BBS: http://16.freebb.com/narp REAL Porsche lug nuts: http://www.boothedesign.com/boltsstudslugs.html Turbo calculator: http://not2fast.wryday.com/turbo/glossary/turbo_calc.shtml 911 Torsion bar to coil conversion chart: http://instant-g.com/Data/911CoilConv.html Engine Tech data: http://www.epi-eng.com/ET_TOC.htm#contents 914 cable shifter manufacturer: http://www.brandwoodcarsllc.com/mofcart/cbindex.html Weber OEM jetting table: http://www.gracieland.org/cars/techtalk/weboem.html Every Automotive Calculator you will ever need: http://www.wallaceracing.com/Calculators.htm Oversteer and Understeer correction sheet and MORE!!!!: http://rogerkrausracing.com/overundr.html Wheel offset calculator: http://www.1010tires.com/WheelOffsetCalculator.asp Intake Manifold Tech: Runner Size Calculations: http://www.team-integra.net/sections/artic...p?ArticleID=466 Distributor Interchange, Bosch To VW: http://www.oldvolkshome.com/ovhignbo.htm Intake extrusions Aluminum: http://www.rossmachineracing.com/products.html Nice gear ratio calculator: http://www.et-studios.com/motorsports/gears/gears.html ITG filters and other cool stuff: http://coastfab.com/specials.html Chandler Products - 12 Point Bolts: http://www.chandlerproducts.com/12point.htm Trick Fasteners: http://www.fitfastener.com F1 Engines Valve technology: http://scarbsf1.com/valves.html Remmele trick Type 4 engine stuff: http://www.remmele-motorsport.com/en/index_aircooled_en.html If I had to use another transaxle?: http://www.theoffroadshop.com.au/services_gearbox_ren.htm |
smontanaro |
Sep 24 2006, 07:49 AM
Senior Member Group: Members Posts: 1,190 Joined: 3-June 05 From: Evanston, IL Member No.: 4,197 Region Association: Upper MidWest |
rhodyguy |
Sep 24 2006, 10:01 AM
classic. please move it admins.
k |
Air_Cooled_Nut |
Sep 24 2006, 10:37 AM
914 Ronin - 914 owner who lost his 914club.com Group: Members Posts: 1,748 Joined: 19-April 03 From: Beaverton, Oregon Member No.: 584 Region Association: None |
The link for the "Dellorto carbs, tech stuff:" needs to be edited to this:
http://www.racecar.co.uk/dellorto/carcarburettors/drla.htm Great list, BTW! |
Twystd1 |
Sep 25 2006, 01:52 AM
Thanks Toby (IMG:style_emoticons/default/drunk.gif)
I corrected the link (IMG:style_emoticons/default/poke.gif) See any other broken links? Clayton |
Matt Romanowski |
Sep 25 2006, 09:10 PM
Senior Member Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 |
There is some really great links up there. Thanks for sharing. I added a bunch of book marks.
Matt |
Twystd1 |
Sep 25 2006, 11:05 PM
Matt.
If ya have any other good ones. Send em too me and I will edit my post. Clayton |
Lo-Fi Version | Time is now: 15th May 2024 - 01:52 PM |
