Hi All,
(Sorry that the last post is attached with pdf that does notr shown the diagrams).
Thanks for the advise last posted.
Finally have time to work on this:
1) I could not find the black/purple wire at the “—“ of the coil.
2) So, I un-pluged the original black/purple wire at back of the tachometer, I run a separate line from the “—“ at the coil to the back of the tachometer directly.
3) The tachometer runs. Good news. It works properly.
So, I have a question about the reconnection:
Can I find the orginal line that was used to connect to the “—“ of the coil in the engine compartment and reconnect that:
1) There was a bundle of wire connected to the “+” of the coil and one was not connecting but with a long plastic plug. (Can not distinguise the colour of the wires)
Is it the original one? How can I test this out .
Diagram 1
Click to view attachment2) Can I find this in the Relay plate box?
AS state in Haynes P161, the Relay plate diagram:
Is it # 7 of X or #5 of Y which show the colour is BK/PU (Black / purple) wiring in the diagram 2.
Can I run a line from this #5 of Y or #7 of X to the “—“ at the coil so as to reconnect the line to the tachometer assuming the original line is not broken and direct to the relay box.
Which one should I use to connect to the “—“ at the coil?
Diagram 2
Thanks a lot.
