ottox914
Oct 2 2006, 04:14 PM
Need to find 1/4 to 1/2 inch more clearance to the back fenders for a new wheel/tire combo. Would prefer to not destroy the paint, (wouldn't we all) but if I have take a few cracks, well, I have to. I have some rust coming back below the sail plane vinyl that needs fix'n, so there may be paint for the quarters in the picture this winter anyway. Don't want to go to GT flairs just yet, still want stock looking contours and fender line, so the sawzall is not the right tool for the job. Used our friend Mr Search, but didn't find what I was looking for. The car is a '73, so the fender lip or return is already notched out around the top of the arch. I need more than to just fold the return back against the underside of the fender, I need 1/4 to 1/2 inch or so on each side.
Anyone got photos of the technique? I've read about everything from plastic pipe to baseball bats to porta-power. Before and after shots? Been there/done that advise on what works, and what does NOT work?
Oh, and I really suck at body work. Hands of stone and no eye for contours. I like rachets and wrenches, not sanding blocks and paint sprayers.
grantsfo
Oct 2 2006, 04:41 PM
pfierb
Oct 2 2006, 06:19 PM
QUOTE(grantsfo @ Oct 2 2006, 06:41 PM)
Eastwood sells a similar tool
JoeSharp
Oct 2 2006, 06:42 PM
They only bend the Lip. If you need to push the fender out they will not work. Joe O'brien got 225 under Liz's car with only a lip roll. But I think it was just luck. Lindas car has 3/4 of an inch on one wheel and 1/4 on the other with 205 50 16's. One inner fender well has rubbed just slightly and the other has about 3/8th clearance. I think there all different.
:PERMAGRIN: Joe
r_towle
Oct 2 2006, 07:35 PM
patience, a heat gun, a hammer, and a dolly covered in duct tape.
heat the paint. not so hot that it bubbles, but make it soft to prevent cracking.
use the dolly on the outside (its covered in duct tape to prevent scratching the paint.)
tap the lip of the rear fender up and try to flatten it out toards the outside of the car.
Start at the front and at the rear of the lip, work towards the middle.
Patience is key.
stop and re-heat the paint frequently to keep it pliable.
If all else fails...
Start with a 1.5 inch pipe and work up to a 3 inch if needed.
put car in neutral.
fit pipe between tire and fender on the top front of the tire, try to hold the pipe as close to vertical as you can...it will end up being closer to 35 degrees, but the idea is to try to keep it vertical.
Roll the car backwards with the pipe going for the ride along the fender
Start with the small diameter, work you way up.
The pipe lengths can be had at HD.
heat the paint frequently.
R
J P Stein
Oct 2 2006, 07:40 PM
It gets even worse for an AX guy.
Both Kumho & Hoosier R specs like -2 camber. You'll find
that you need a spacer to run 225s and these are considerably wider that a "normal" street tre.....bout a 7mm spacer & longer studs/bolts.
.....and since low is better, the fat part of the tire is right around the lip.
I couldn't get away from some serious hammer/dolly work to get 225 Hoosiers & 7 inch wheels in back.
larryp
Oct 3 2006, 03:40 PM
It's easy. I have done it and there is nothing to it. Forget about heating the paint -- you'll be too busy. You can try, but you'll need a third person to hold the heat gun and they are just going to get in your way, anyway.
Go to a parking lot or a driveway. With a friend. And a wood baseball bat. Inflate your rear tires a bit more than you would drive on them (+6 to 10 psi). Have your friend get in the car and start it.
As for you, take the baseball bat and stuff it at the bottom of the fender gap between the tire and the lip. It will look like it will not fit but it will - the tire will deform a bit and the fender will bow out (ergo, overinflate your tire, you want to displace more fender and less rubber). The bat will be angled but you will be holding it. With the drivers window down, have your friend ease out the clutch and you commence rolling the bat (you basically guide it; the tire does the rolling) around the fender. You can yell stop whenever you wish but you will eventually have the fat end go completely around 3-5 times. Your friend can go forward and back, forward and back.
Ignore the cracking and popping; that is unknown bondo and/or old paint. Do not start this expecting not to have some minor paintwork done. You will.
Now walk around the car and do the passenger side. When you are done it will easily take a 7" rim and a 205 tire.
Do it more than you think you need to. Then do it again once or twice. You do not want to decide "gee, I should'a done it once more" after the car is painted.
Aaron Cox
Oct 3 2006, 03:49 PM
QUOTE(larryp @ Oct 3 2006, 02:40 PM)
AHHH, fender pics pricks?
jhadler
Oct 3 2006, 05:22 PM
I used a similar method, but was a little less subtle.
I took a hefty piece of lumber, shaved one end so there were no hard edges or points, and went to town...
I did mine solo, with the car stationary. In gear, brake on.
Lots of air in the tire, with a tire and wheel that were sturdy.
Jacked the car up and raised the spring perch (I have adjustable perches), so the desired tire/wheel combo (225/50-15 on 8" wheel) no longer hit the fender lip. Inserted the "fenderizer" between the jacked up fender and tire. Slowly lowered the car on the fenderizer, and then levered the bar down till it was flat against the wheel, pulling the fender out away from the car. Did this repeatedly along the length of the fender, then lowered the spring perch about a 1/2", and did it again. I continued to do it 'till the perch was at the bottom, and I met no more resistance while leveraging the fender away from the tire. It took a while to do both fenders, and one of them had the paint crack a bit, but it came out nicely I think. Especially for the cost....
Someday, I'll get the car repainted, and fix up the cracked paint.
Here's a couple pics of the (un)finished product....
-Josh2
Click to view attachmentClick to view attachment
Bleyseng
Oct 3 2006, 05:42 PM
I started with the wooden bat, went to a aluminum bat and finally a old boge front shock. The shock worked the best...
cracks the paint some but I got 7" cookies with 205x50's w/ Kuhmo's to fit nicely.
J P Stein
Oct 7 2006, 09:22 PM
As I said, lower is better. An old pic.
The jacked up look is for drag cars & 4 X 4s.
Just my opinion of course.
(edit) an summore free advice. When seting up your car, you should check the full range of suspension travel for tiar clearance. Lock to lock in front. This means disconnectinng/removing the springs/T- bars leaving the shocks in place as those contain the bump stops..... a couple of jacks & have at it.......again, IMO.
ottox914
Oct 7 2006, 10:34 PM
Did a little bending tonight- I'll post some pics and commnets after tomorrows auto x.
Mueller
Oct 8 2006, 01:10 AM
Nice work fellas. Wish I would have seen this a few months ago.
John Kelly
Oct 8 2006, 08:51 AM
Hi Mike,
Doesn't look like you are staying up away from the wheel opening detail when stretching? If you stretch anywhere within 2" of the opening, you are in danger of losing the detail or making it more shallow in just the area where you stretch the most. Unless that is the look you want?
John www.ghiaspecialties.com
ottox914
Oct 9 2006, 09:25 PM
Here's what I ended up doing. Put the keizers and 205-50 710's on. Grabbed a 1" pvc pipe, and jammed it up between the wheel and fender. Rather than rolling the car, I just grabbed the pipe and turned it, which served to flatten the lip, and pull the fender. The lip flattening was probably 95% of the result, the fender pulling was maybe 5%. As expected, one side was tighter than the other, in my case, the driver side was a tighter fit than the passinger side. Camera batteries were dead, so no pics of this. Some paint was damaged. All this happened on saturday. We test fit the race rubber, had a quick spin around the block, drove some figure 8"s in the local high school lot, and seemed to have no rubbing. So far, so good.
Sunday was an auto cross. I put 2 test markings on the back tires, as the fronts were never a problem to rub. On each tire, I placed a single strip of duct tape, from the tread to the rim, and in a second spot, layered 2 strips of tape. No rubbing on the passinger side, the layered test strip on the driver side was tore up, the single strip was a little cut, but not enough to get to the rubber.
So I was able to fit 15 x 7, 5" backspace keizers with 710's on the front and rear of the car, with 1/2" spacers in the front, none in the rear, no rubbing in the front, and really, no rubbing in the rear, with just bending the lip, or fender return, up a little. Keep in mind the margin of clearance was measured in the thickness of duct tape...
The next step in the plan, was to find a friend who does this-
and has tools like this.
ottox914
Oct 9 2006, 09:28 PM
then you ask him to do this-
and end up with this.
Mueller
Oct 9 2006, 09:29 PM
QUOTE(ottox914 @ Oct 9 2006, 08:25 PM)
I hope you have a lot of band-aids.......
ottox914
Oct 9 2006, 09:30 PM
then you do some of this-
and end up with tires that fit.
There is still more to be done. I plan to use a block of wood and a jack to try to push the fenders out just a little more. I've got maybe an 1/8th at the most, but thats more than 1 thickness of duct tape. Don't have any photos of how they fit after the cutting, but will try to shoot some and add to the thread. Dave-O has some pics of the car and rims/skins from the auto cross, if he remembers to add them to this post. Recall that was with the lips folded back, and I've probably doubled or more the clearance with the cutting. The rest of the job will include- final sanding of the bent metal to remove any burrs prior to a splash of paint. For now I may try just to tape off the top of the edge of the fender detail, and spray a little around that 1/2" or so of fender, and of course spray the inside edge and back side.
ConeDodger
Oct 9 2006, 09:39 PM
QUOTE(Mueller @ Oct 9 2006, 08:29 PM)
Didn't you see the heating and cooling truck Mike? This guy is probably cut up all the time...
ottox914
Oct 9 2006, 09:42 PM
QUOTE(Mueller @ Oct 9 2006, 07:29 PM)
The band-aid was from an oooops Steve had earlier in the day- no blood was spilled in the minor fender mods we did tonight. And yes, he is cut up now and again, but has hands of leather. Interesting guy- he's been dead 2x, and came back 2x. Loves his twin daughters and his 1st gen RX-7's. Is always after me to do a 13B swap into the 914. A good friend to have around.
Aaron Cox
Oct 9 2006, 09:46 PM
why didnt you just fold the lip up? no sharp edges....no slit tires
Dave-O
Oct 9 2006, 09:57 PM
The picture fairy is here
I like the dissapproving look of Nancy in the back of that one picture!
jd74914
Oct 9 2006, 10:07 PM
sorry to hijack, but do you have any pictures of the yellow bimmer?
ottox914
Oct 9 2006, 10:14 PM
QUOTE(Aaron Cox @ Oct 9 2006, 07:46 PM)
I thought about just folding them over tight on the inside, but as I live in a part of the country where is actually rains, and I can get stuck in it, I thought that would be a perfect water trap, and rust spot, and the thought of the fenders starting to rot off at the edges and look like an 80's chevy p-up didn't set well with me.
We cut the returns off awfully close to the horizontal, or bottom edge of the lip, then used hammers and 1000 little tap tap taps to form a small rolled return on the back, cut edge. The clearance from the fatty fat tire to the newly rolled edge of the lip had doubled, or trippled. I think the tap tap taping on the edge, to get the slight roll, may have pushed the fender lit area out just a bit more also.
ottox914
Oct 9 2006, 10:17 PM
Hey Dave, thanks for the pics! Nancy was looking on, but keeping her distance, as we were men on a mission with tools and no fear. I think she knew she didn't have a chance on this one.
As far as more bmw pics, haven't seen them come up on the club site so far.
John Kelly
Oct 10 2006, 08:41 AM
Hi David,
For a little more clearance, you can cut the rear most quarter panel brace loose, and pull the quarter panel out a little and re-weld. For a little more than that, you can put a jack under the area where you cut the brace loose and lift the car slightly. This will push up and out.
ottox914
Oct 10 2006, 08:43 AM
QUOTE(John Kelly @ Oct 10 2006, 06:41 AM)
Hi David,
Nice tips, John. Any pics you can add?
John Kelly
Oct 10 2006, 03:30 PM
[/quote]
After stretching Zach's fenders, we cut the brace, pulled and re-welded...might do more later. Picture attached.
