QUOTE(Mark Henry @ Oct 2 2006, 09:30 PM)
QUOTE(shaggy @ Oct 2 2006, 11:45 PM)
....so what is it?(simply)
and how do i determine it?
thanks
-shaggy
It is not a "simple" task!
Stock or Hi-Po?
It takes
time, an adjustable pushrod, shims, maybe a lathe to cut the pushrods, etc. You need to know you lift.
Aaron is right about the half lift bit...stock is not that bad, hi-po is more work.
mark - care to elaborate on the differences between hipo and stock for jimbo?
my setup - manton cromo CTL pushrods... 1.7 rockers with oem 911 swivels. rockers were decked .060, and i think to get it dead nuts i had .060 rocker shims....
mark can explain it better than i
