A TV dinner
Oct 12 2006, 11:34 PM
well its come down to this. i an almost mechanically finished with the teener. i recently picked up a remanufactured fuel pump with 4 remanufactured injectors, all of which work correctly. when the parts are installed however, two of the male plugs off of the wire harness dont work. plugs for cylinder injector numbers 1 and 4.
what going on here, im pretty much at a dead end????
thanks
~alex~
bottomend
Oct 12 2006, 11:36 PM
Obvioulsy it's the mismatched wheels. Try reversing them and see what happens. Pease post results.
A TV dinner
Oct 12 2006, 11:44 PM
QUOTE(bottomend @ Oct 12 2006, 09:36 PM)
haha well i figured if i kept the pretty wheels closer to the engine, the car would work in my favor.....BUT its obviously not.....wierd reasoning huh....
bd1308
Oct 13 2006, 12:05 AM
Trigger points at the base of the distributor. D-jet fires in alternating pairs, mmaking a X pattern on your engine. 1/4 and 2/3 get juice at the same time, check for corroded wires at trigger points connector, or check the trigger points themselves. I have two floating somewhere in ohio.
Heeltoe914
Oct 13 2006, 01:02 AM
Also check the Eng, block grd.
Mueller
Oct 13 2006, 01:18 AM
I take it you have never seen this site???
Brad Anders D-jet infoexplains the hows and whys and how to troubleshoot they system..
dmenche914
Oct 13 2006, 02:26 AM
A failed power transitor in the D-jet brain will also cause these injectors to fail, there are two power transistor that serve two each injectors. If the injector wires get accidently shorted to each other, that can kill the power transisto in the brain, don't ask how I know that one. Hope it is something simple like the trigger points or a bad ground. you might also fry the transistor with an ohm meter across the injector wires that go to the brain. it was a major OPPS on my part some years ago
tdgray
Oct 13 2006, 06:59 AM
If that turns out to be the case (brain I mean) I have an extra brain.
I also have Britts trigger points
