QUOTE(brownaar @ Oct 15 2006, 08:35 PM)
My driver's side headlight is dim. I suspect it probably is a bad ground or poor connection somewhere. Any suggestions about where to start looking? Any chance it's the bulb? I have H-4's and will switch out the bulbs to see if the problem stays on the same side. I suspect it will.
Thanks
Mantra for 914 Electrical Problems... Repeat after me....
"Check the grounds... Clean the grounds...."
The headlight grounds are located by the headlight motors. Pull the nuts off and clean both the ground point and the loop connector. Inspect the wires at the loop connector for any fraying or breakage.
