I believe that there's (virtually) no such thing as too much brake.
I don't disagree with that as long as it's a well thought out system. The problem is in the following areas:
1. People constantly think they are under-braked when really their brakes be broke. New pads, new fluid and new lines would solve their problems.
2. A lot of people don't seem to have enough money to perform proper rust maintanence on their vehicles, yet they are eager to follow the masses suggesting their brakes suck. This gets expensive fast.
3. Most people have a 1.7-2.0 95hp max engine, a narrow body teener and stock size rims with the largest rubber they can fit. You have a 3.6 993 Euro spec six cylinder with a maxed out trick 915 in your car. You also have flares and a massive amount of very expensive rubber on your car.
4. You have more in your brakes than most people have in their cars. I realize not everyone would go that route but... for a majority of 914 owners with warmed over 4 cylinder engines, that would be money wasted.
5. Any amount spent on larger calipers or BMW "upgrades" could be better spent for your average teener. Do you have a sway-bar? How about a nice set of Konis? How about some Elephant or Roller bushings? How about a hell hole kit and fix some rust? How about putting that toward a nice paint job?
6. Most people throw caution to the wind and simply bolt up "anything" that has a 3" ear and fits their solid rotor without thinking that maybe, just maybe, there was a Porsche engineer at the other end of their brake system. When Porsche changed the front brakes on the 914, they also changed the rears...ya think? How many so called "upgrades" can make that claim?
I'm not diss'n on Joe. If you have that amount of money to spend on brakes and that's what you want, do it. Spend the time to think it through as a Porsche engineer would, get the proper balance and write some checks. There is absolutely nothing wrong with Joe's brake system (except maybe a handbrake... but that can be rectified, write more checks). I think he did it right. Those brakes won't even break a sweat.
I just like to look at this as a practical application. We are in JPB's thread here and I believe he has a 4-cylinder narrow body teener. Most people here do. Most people here haven't spent a great deal of time getting:
a ) Excellent Pads. (let's face it... how many have coughed up $100 for a set when you can get a set for $25??)
b ) Changing their fluid every 6 months.
c ) Excellent tire/rubber compounds.
d ) New rubber lines.
e ) A properly bled system.
Bottom Line. Brian Redman in JPB's car with the same tires and a well set up brake system and Brian Redman in JPB's car with the same tires and the largest brakes you can find, would probably stop within the same distance. The difference is money.
