From CL
http://sfbay.craigslist.org/eby/pts/223513565.htmlNothstar V8 and trans
Northstar 32 valve all aluminum motor, 300 hp, dual over head cams. Very complete.
Includes: all accessories and brackets, exhaust manifolds, ps pump, map sensor, computer, wiring harness,coil packs, throttle body, water pump, alternator is cracked but bracket is fine, plugs, wires, you get the picture, it's all there. This over $2000 worth of parts over and above the motor itself if you are putting it in a buggy or something and had to get them all seperatly. I didn't ask the mileage or year of the Caddy but the engine line date is 7-19-95 so it was probably a '96 model year. I took it our of the guys garage with the crashed car next to it 5-6 years ago. I'm coming to realize that I'm not going to get to build the buggy I dreamed of any time soon so I'm selling the motor.
In case you want to know it weighs 510 lbs.(complete, dry) without the trans. Great for a hot rod, sand car, or rockcrawler.
It's very clean but I found a crack in the intake from the accident, might be fixable but it's easier to replace it with a stock one or an aftermarket one if you are going to hot rod the motor. It is all intact.
It also includes the 4T80E Hydromatic transmission and trans axle out to the inner Cv joints. Trans pan is cracked but can be tig welded and used
