DNHunt
Nov 15 2003, 08:05 AM
Here is the inside of the passenger framerail after it was treated with metal ready
DNHunt
Nov 15 2003, 08:07 AM
Hereit is after putting Por 15 in the opening
DNHunt
Nov 15 2003, 08:11 AM
FINISHED welding and grinding drivers aide inner wheel well, firewall and engine shelf. I know my welding is not pretty but its stuck good so I'mm happy. I think it's gonna be fine
Dave
John Kelly
Nov 15 2003, 08:50 AM
Hi Dave,
Nice job!
John www.ghiaspecialties.com
DNHunt
Nov 19 2003, 08:24 PM
Getting ready to start painting this weekend. First Metal Ready then Por 15 on bare metal. Finished lightly sanding engine bay paint for to recieve primer later. Tidied up weld seams. Pasenger side
DNHunt
Nov 19 2003, 08:25 PM
Driver's side No fun getting all the old grime off. Since I plan to paint the engine bay I used laquer thinner which cut it pretty well.Took a lot of the gloss off too.
Aaron Cox
Nov 19 2003, 08:28 PM
way to go!
kafermeister
Nov 19 2003, 08:40 PM
NICE!
2-OH!
Nov 20 2003, 12:27 PM
Dave:
Did you take the Wiring Harness out or are you going to just tape off around it.
I still have to get the final horse hair off the firewall..Did the Laquer Thinner work on that old glue ???
2-OH!
DNHunt
Nov 20 2003, 12:35 PM
I left the wiring harness in and I'm working around it. Pain in the butt but, I'm lazy.
Lacquer thinner and elbow grease in equal parts.
Dave
DNHunt
Nov 22 2003, 04:20 PM
MORE RUST FOUND.
Pasenger door down low
DNHunt
Nov 22 2003, 04:23 PM
Trunk. By the way my pad under the carpet was sopping wet. I hope it was from the stean cleaning about a month ago
DNHunt
Nov 22 2003, 04:24 PM
Driver's door in the seal channel
DNHunt
Nov 22 2003, 04:26 PM
Trunk prepared for Por 15
redshift
Pad under carpet in trunk....
Hey Dave, if you care at all about your car, remove the padding under the carpet in the trunk, and the carpet over the padding in the trunk.
Take all that out.
M
DNHunt
Nov 22 2003, 04:27 PM
Another view of the trunk
DNHunt
Nov 22 2003, 04:28 PM
Gotcha Miles
Thanks
Dave
DNHunt
Nov 22 2003, 04:30 PM
Cut out the rust in the channel in the driver's door
DNHunt
Nov 22 2003, 04:31 PM
Patch welded in
rhodyguy
Nov 22 2003, 06:46 PM
you're getting really good dave!!! welds are looking nice. you must have been expecting the worst til' you got the seam seal off in the trunk. where are you going from this point? still on the "hunt" or getting ready to start buttoning things up? you going to do the suspension while it's up in the air?
kevin
DNHunt
Nov 22 2003, 10:11 PM
Kevin
I wish I could say the welds are looking nice. They are a little better but, the grinding is getting really good.
I won't commit to being done with the hunt. Every time I think I've found the last of the rust I find more.
I did kinda jumped the gun on the trunk. But, I couldn't foresee that there wouldn't be rust under the seam sealer. Everywhere else it has hidden some. At least it was easy to get to. Only took about an hour to clean up.
Vacuumed really well this afternoon and wiped all the affected areas with tack cloth. Gonna start treating the bare metal tomorrow
Dave
Brad Roberts
Nov 23 2003, 05:51 AM
I throw away customers' SPONGES. They ask me "where did my pad go" and I point to the dumpster.
Dave everything is turning out REAL nice. Good job.
b
DNHunt
Nov 23 2003, 12:14 PM
Treated all the bare areas with Metal Ready. Stuff smells nasty. It turned all the areas with any rust black as advertised. Headed out to do a lot of rinsing.
Dave
DNHunt
Nov 23 2003, 08:18 PM
Metal etched and ready for Por 15.
DNHunt
Nov 25 2003, 07:07 AM
Painted the center tunnel with Por 15. Used Metal Ready to prep it. The car is on jack stands with the nose down a couple of degrees. Poured about 1/4 cup of Por 15 in the aft inspestion port then used the air compressor and gravity to flow the paint down the tunnel. Worked really well. I used the excess to paint around the petal cluster.
DNHunt
Nov 25 2003, 07:09 AM
Great way to paint. Quick and dirty
Dave
redshift
Nov 25 2003, 07:19 AM
Hey Doc, my car is next!
Good job, how's that eye doing?
M
DNHunt
Nov 25 2003, 07:25 AM
Miles
Only one problem. I hope I never have to do this again. (I know they never stop rusting) You'll have to do your own.
Eyes great. Thanks for your concern
Dave
redshift
Nov 25 2003, 07:32 AM
It's everyone's dream to have the perfect machine.
It's my dream to have Ed McMahon drive it here from somewhere else, so I don't have to take 3 years of crap off of JP when I start spraying primer.
M
DNHunt
Nov 25 2003, 09:47 PM
Hit on an idea to get Por 15 between the inner and outer lower firewall. I injected about 50cc's of Por 15 through the tubing into the space. Then I blew the hell out of it with the compressor to spead it around. If it works anything like it did for the center tunnel it should do a pretty good job.
Dave
DNHunt
Nov 26 2003, 01:24 PM
Nice to see an end in sight. Brushed on Por 15 in the front trunk. I think it looks pretty darn good
Dave
Nov 26 2003, 01:49 PM
QUOTE(DNHunt @ Nov 25 2003, 07:47 PM)
should have used the metal ready for the forced injection
looking good!
Andy
