Thorshammer
Nov 15 2006, 07:15 PM
Click to view attachmentThis is a much better picture of the shift box. The handle is cnc'd and the box is a fabbed unit. with the side plates milled for access to the shift lever bolts and adjustments. The box is held to the car with 8mm riv nuts into the sheet metal. I think I would weld bungs into the car if I did this again. The bottom of the shift lever has a heim rod which attaches to the front of the shift box via a short rod, and the for aft adjustment is adjusted at this point. You will also need a large bolt somewhere in the shift rod to allow for left to right rotational adjustments. I use a 14mm bolt and it is double nutted to do this.
Erik
Thorshammer
Nov 15 2006, 07:17 PM
Click to view attachmentThis is really a pic of the exhuast fab, but the trans and linkage is in view.
Erik
Thorshammer
Nov 15 2006, 07:19 PM
Click to view attachmentMore exhaust, but some transmission
Erik
Thorshammer
Nov 15 2006, 07:22 PM
Thorshammer
Nov 15 2006, 07:38 PM
Jeroen
Nov 15 2006, 08:02 PM
Eric, thanks for sharing these pics
Any chance of a clearer shot "inside" the shiftlever housing?
Thorshammer
Nov 15 2006, 08:07 PM
No,
I'm embarrased, but the car is at my mother in laws garage. I have too much work here. Its killing me. Those are the only photos I have at this time.
Erik
Brett W
Nov 15 2006, 11:41 PM
Kevin you need to flip the tranny. This will allow you to lower the engine and tranny. Right now the engine has to sit relatively high. If you flip the tranny you can get about 3in (If I remember right). Would allow for better axle alignment on super low race cars, plus it leaves all of your linkage and such clear of the exhaust.
groot
Nov 16 2006, 06:41 AM
Great idea, but it ain't legal... and the starter will be in the way of the header.
From the GCR:
6. Motor mounts of alternate design and/or material may be used, but there shall be no change to the engine’s fore and aft or vertical location. Transverse engine vehicles may rotate the engine about the crankshaft centerline to align axles/CV joints. On rear engine/rear drive cars the engine/drivetrain may be relocated vertically upward, to a maximum of one (1) inch, to allow alignment of suspension and driveline components. No other engine rotation or relocation is permitted on any car.
Brett W
Nov 16 2006, 11:17 AM
DOH!!! Damn rules.
Brad Roberts
Nov 16 2006, 11:59 AM
Whoa.. Erik!
That tranny is a REALLY old version. They stopped using the exposed "Monkey motion" in the early 70's!! You could bump an open wheeled racer from behind using this linkage and knock the car out of gear..LOL They went to the enclosed linkage!
Great shots. I recall seeing them now
I like how you suspended the engine in the chassis. Like a Pro Stock drag car "motor plates"
B
Thorshammer
Nov 17 2006, 08:48 PM
The trans is circa 1972. Whe the aircooled SV's were introduced. and yes you could bump a SV out of gear from the rear, however only in 5th and 3rd.
Many people said this wasn't going to work, and was'nt strong enough. i don't even have MK 5 gears. Primarily because I did not have enough cash to buy Mk 5 gears. The mk 9 stuff worked fine for me. Your breakage may vary.
One side note, I clutch all upshifts and all down shifts. and try to limit the shock on the trans during downshifts by matching the rpm as best I can.
Erik
Brad Roberts
Nov 20 2006, 12:53 AM
Can you explain this to the home user?
I gather from what you said:
Full throttle upshift but clutch in for upshift and downshift.
If Erik wanted to change the actual gears every 5-6 races in the tranny he could feasibly perform full throttle clutchless upshifts (and downshifts) This option gets expensive quickly.
I would imagine he is "stabbing" the clutch or just touching it during the full throttle upshift.
I have a question for Erik:
What about an iginition interupt for the upshift?
B
Thorshammer
Nov 23 2006, 02:35 PM
Actually I lift very slightly for every shift. It is a small lift, But I don't find the advantage in lap times shifting with my foot matted and the RPMS climbing like crazy. I just haven't seen the need. I know the flywheel effect will give the car a momentary push. I have looked at data systems on cars being shifted like this, and the shift time isn't really reduced. If it is, it is a very. very small decrease. I just don't think the component stress is worth the limited decrease in time between gears.
So let me recap, when nearing the shift point I stab the clutch and pull the handle, while I slightly lift my foot off the gas. Then I mat the gas pedal as the the clutch is already released. It pretty quick, you can hear the shift on my race videos. It's faster than anything else I have heard in a 914. Plus the rpm drops are calculated so that the engine is in the power all the time. I think that is a really big advantage against the Limited prep crowd. If you can gear it and keep it in the power more than the other huy you have an advantage. This is 50% of the reason I choose to do a Hewland.
Todd at TCE does alot of formula mazda transmissions, He has a mk5 geared trans in a pikes peak hillclimb car that has 320hp or so, and he has put it in a special gearcase and it uses the mk 5 gears and he has no problems. This may be a answer for some of you. I don't think the FP/EP crowd has a problem. Ed Givler and I had HEwlands for the past two years with no issues. And MK 9's as well, no mark 5 gearsets.
Erik
edgetoo
Dec 4 2006, 11:45 AM
I have been using Hewland/Webster transmissions for 34 years. (We shouldn't be
trying to convince you folks to go this route, they really work well!!!) (Your E & F
prod compeditors have been using Dog Clutch non syncro boxes for years.)
They are slide on, interchangable, Dog engagement, straight cut gears housed in
a modified VW type 1 case. (Webster is an American copy of the English box.)
The MK 5, MK 8, & MK 9 are made in 4 & 5 speed and will bolt to VW type 4 with
VW type 4 flywheel. (Slightly longer axles are needed)
Air Cooled FSV, & F-Mazda configurations have the shift on the right side. (While
the exposed rear shifter of the ACFSV could be "bumped" into neutral, a small
shifter bumper will prevent this.)
Water Cooled FSV, FF, F2000, S2000, and Sports racer configurations have the
shift lever on the left side. (These may have had the starter flange removed.)("Rino" VW type 1 cases are inexpensive and are stronger.) (Some sideplate
appendages may need to be removed to clear some starters)
If you wish more details, let me know.
Ed Givler
Brad Roberts
Dec 4 2006, 01:15 PM
Ed,
I like the idea of running the Rhino tranny case with the Hewland/MK setup. Great idea!
Do you run a 914 with a dog box??
B
edgetoo
Dec 6 2006, 01:05 PM
yep!
Ran a AC FSV for almost 30 yr before going to an FP 914-4 (FSV with fenders!). Have had the Hewland and Blake's motor in it for 2 yrs. (It now shifts like a race
car!)
Ed
groot
Dec 6 2006, 01:44 PM
Just an update on my 915 BS.... I got a refund from the dude who sold it to me and I'm going to ship it back to him.
In the mean time, I'm going to run a 901 until I move to a Hewland.
