If you are going to stiffer rear springs are they also shorter in length than the originals?
IF your new springs are shorter you will only need your new spring compressor to get the old springs off of your shocks...
the new springs can be installed without the need for the compressor due to their shorter length...
By the way you remove the entire shock/spring combo from the car and then use your compressor to get the stock springs off of the shocks.
