Specs out of the technical specifications hand book claim 2139 lbs. So what I am looking for is a factory document that says it is lighter than this. Hopefully significantly. This also does not list if it is for a -4 or a -6 just the weight. And I am noit sure if that is dry weight or wet
I have R&T data that shows 2085 - 70 -4; 2195 -70 -6; and 2250 fot a 76 -4 I have found test data down to 1940 - 4. But it is not factory offical, but car test from early mag articles. I have also found Jurgen Barth notes of 900 Kg, converts to 1984 pounds.
So why do I want it to be offical. My auto-x class allows 100 pounds off with out taking points. So if I have a documented offical weight, I can work from there. I would have to add ballast when I play with SCCA in SM 2 for me it is 2100 but is that with driver or with out driver?
