biosurfer1
Dec 7 2006, 02:55 PM
I need to make a jumper for my headlight relay, but I'm not an electrical guy at all, so I wasnt sure what this part is called that allows you to put 2 (or more) female connectors on the headlight terminal. I was trying to explain what i needed to the guy at the hardware store but just got a blank look..is there a technical term for one?
Joe Bob
Dec 7 2006, 03:06 PM
I just take what I got to the electrics guy and say...I wants DIS!.....then I look at the box for the discription....
Crazyhippy
Dec 7 2006, 03:12 PM
i use thingamajig...
but doo-hickey works as well
BJ(take on in w/ you)H
TravisNeff
Dec 7 2006, 03:17 PM
Hermaphrodite Terminals. lol
MoveQik
Dec 7 2006, 03:23 PM
It's the Utah connector. It allows several females to be connected to one male.
cooltimes
Dec 7 2006, 03:26 PM
An inline multi receptable is what I would call it but can't ever recall seeing one for the multiple spade setup you are wanting. I am thinking you will have to make it yourself. If someone else can do it, you could too.
MikeCool
bondo
Dec 7 2006, 03:27 PM
The female plugs that have a male tab on them are called "piggyback connectors". Not quite what you have there, but close. Does that help?
pbanders
Dec 7 2006, 03:32 PM
You can buy these piggyback connectors at most auto parts stores, in the electrical aisle
bondo
Dec 7 2006, 03:34 PM
Found it. Part number 8019K86 at mcmaster.com. I hope you needed 25 of them.
JeffBowlsby
Dec 7 2006, 03:39 PM
Ummm try FLAPS? Radio shack? Decent hardware or electronics stores. These are common parts.
biosurfer1
Dec 7 2006, 03:44 PM
thanks, thats actually a picture of what i need, not my pic...i'll try piggyback connector. duh, i should have thought to try radioshack:)
Dec 7 2006, 04:13 PM
QUOTE(biosurfer1 @ Dec 7 2006, 12:55 PM)
- I need to make a jumper for my headlight relay
- I'm not an electrical guy at all
these two concern me ...
may i ask WHY you *need* a jumper for your headlight relay ???
Andy
biosurfer1
Dec 7 2006, 05:02 PM
because its one of the new 5 prong relay and there are only 4 connections. jumpering 30 to 56.
I'm following advice YOU gave in this thread:)
http://www.914world.com/bbs2/index.php?show...c=16320&hl=(i meant i'm not an electrical guy in the sense I don't know the technical terms for everything, I do know how not to shock myself:) )
jd66921
Dec 7 2006, 05:49 PM
Radio Shack part # 64-3064
Quick connect adapter set.
It contains 8 different tyopes for under$2.00
Jeff
Dec 7 2006, 05:57 PM
QUOTE(biosurfer1 @ Dec 7 2006, 03:02 PM)
ok, i feel better now ...
don't know what they're called in english, but any good electronics store will have them ...
piggy-back seems like a good word ...
Andy
biosurfer1
Dec 7 2006, 06:04 PM
thanks jeff...i'll hit up "da shack" after work...maybe i'll have TWO headlights after tonight!
jd66921
Dec 7 2006, 07:50 PM
Glad I was able to help, finally!
Jeff
jd66921
Dec 7 2006, 08:22 PM
By the away, if you can't find any, I have plenty. PM me!
Jeff
914werke
Dec 7 2006, 09:45 PM
Your kidding no one ?......"flux Capacitor"
biosurfer1
Dec 7 2006, 11:09 PM
well radio shack had them, plug it in and worked great...only problem was the headlight still didnt work, so I went through every fuse again and i must have said the magic curse word this time becasue it works now...just one more reason to get the blade type fuse holder :/
mightyohm
Dec 8 2006, 12:53 AM
do yourself a big favor and get all new fuses for the fuse panel!
they oxidize and make bad connections over time. a nice short term fix is to rotate the fuses in the holders a few times.
ConeDodger
Dec 8 2006, 12:59 AM
QUOTE(SirAndy @ Dec 7 2006, 03:57 PM)
Andy
Just say it German Andy... We have all heard bad words before.
TINCAN914
Dec 8 2006, 07:23 AM
QUOTE(biosurfer1 @ Dec 7 2006, 05:04 PM)
I was looking for the same thing last month. Went to Radio shack, and three FLAPS and no luck. It's off to McMaster I go.....
biosurfer1
Dec 8 2006, 09:48 AM
tincan...if your radio shack has all the setup with all the trays, with the leds, switches, etc. they should have them, they were in the back of the "wire connections" tray.
I got all new fuses, they will be going in tonight.
