Stupid electrical question, what is this piece called? |
biosurfer1 |
Dec 7 2006, 02:55 PM
Teener fo Life! Group: Members Posts: 3,020 Joined: 3-August 03 From: Roseville, CA Member No.: 977 Region Association: Northern California |
I need to make a jumper for my headlight relay, but I'm not an electrical guy at all, so I wasnt sure what this part is called that allows you to put 2 (or more) female connectors on the headlight terminal. I was trying to explain what i needed to the guy at the hardware store but just got a blank look..is there a technical term for one?
Joe Bob |
Dec 7 2006, 03:06 PM
I just take what I got to the electrics guy and say...I wants DIS!.....then I look at the box for the discription....
Crazyhippy |
Dec 7 2006, 03:12 PM
Insert witty comment here... Group: Members Posts: 1,659 Joined: 28-July 05 From: Home of the Coyotes, AZ Member No.: 4,493 Region Association: None |
i use thingamajig...
but doo-hickey works as well BJ(take on in w/ you)H |
TravisNeff |
Dec 7 2006, 03:17 PM
Hermaphrodite Terminals. lol
MoveQik |
Dec 7 2006, 03:23 PM
What size wheels can I fit? Group: Members Posts: 4,645 Joined: 5-April 05 From: Scottsdale, AZ Member No.: 3,881 Region Association: Southwest Region |
It's the Utah connector. It allows several females to be connected to one male. (IMG:style_emoticons/default/w00t.gif)
cooltimes |
Dec 7 2006, 03:26 PM
Advanced Member Group: Members Posts: 2,508 Joined: 18-May 04 Member No.: 2,081 Region Association: None |
An inline multi receptable is what I would call it but can't ever recall seeing one for the multiple spade setup you are wanting. I am thinking you will have to make it yourself. If someone else can do it, you could too.
MikeCool |
bondo |
Dec 7 2006, 03:27 PM
The female plugs that have a male tab on them are called "piggyback connectors". Not quite what you have there, but close. Does that help?
pbanders |
Dec 7 2006, 03:32 PM
Senior Member Group: Members Posts: 939 Joined: 11-June 03 From: Phoenix, AZ Member No.: 805 |
You can buy these piggyback connectors at most auto parts stores, in the electrical aisle
bondo |
Dec 7 2006, 03:34 PM
Found it. Part number 8019K86 at mcmaster.com. I hope you needed 25 of them. (IMG:style_emoticons/default/smile.gif)
JeffBowlsby |
Dec 7 2006, 03:39 PM
914 Wiring Harnesses Group: Members Posts: 8,505 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Ummm try FLAPS? Radio shack? Decent hardware or electronics stores. These are common parts.
biosurfer1 |
Dec 7 2006, 03:44 PM
thanks, thats actually a picture of what i need, not my pic...i'll try piggyback connector. duh, i should have thought to try radioshack:)
Dec 7 2006, 04:13 PM
- I need to make a jumper for my headlight relay - I'm not an electrical guy at all these two concern me ... (IMG:style_emoticons/default/biggrin.gif) may i ask WHY you *need* a jumper for your headlight relay ??? (IMG:style_emoticons/default/confused24.gif) Andy |
biosurfer1 |
Dec 7 2006, 05:02 PM
because its one of the new 5 prong relay and there are only 4 connections. jumpering 30 to 56.
I'm following advice YOU gave in this thread:) http://www.914world.com/bbs2/index.php?show...c=16320&hl= (i meant i'm not an electrical guy in the sense I don't know the technical terms for everything, I do know how not to shock myself:) ) |
jd66921 |
Dec 7 2006, 05:49 PM
Member Group: Members Posts: 316 Joined: 9-January 06 From: Texas Member No.: 5,394 |
Radio Shack part # 64-3064 Quick connect adapter set. It contains 8 different tyopes for under$2.00 Jeff |
Dec 7 2006, 05:57 PM
I'm following advice YOU gave in this thread (IMG:style_emoticons/default/smile.gif) ok, i feel better now ... (IMG:style_emoticons/default/biggrin.gif) don't know what they're called in english, but any good electronics store will have them ... piggy-back seems like a good word ... (IMG:style_emoticons/default/smile.gif) Andy |
biosurfer1 |
Dec 7 2006, 06:04 PM
thanks jeff...i'll hit up "da shack" after work...maybe i'll have TWO headlights after tonight!
jd66921 |
Dec 7 2006, 07:50 PM
Glad I was able to help, finally!
Jeff |
jd66921 |
Dec 7 2006, 08:22 PM
By the away, if you can't find any, I have plenty. PM me!
Jeff |
914werke |
Dec 7 2006, 09:45 PM
"I got blisters on me fingers" Group: Members Posts: 10,059 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Your kidding no one ?......"flux Capacitor" (IMG:style_emoticons/default/av-943.gif)
biosurfer1 |
Dec 7 2006, 11:09 PM
well radio shack had them, plug it in and worked great...only problem was the headlight still didnt work, so I went through every fuse again and i must have said the magic curse word this time becasue it works now...just one more reason to get the blade type fuse holder :/
Lo-Fi Version | Time is now: 14th May 2024 - 09:57 PM |
