The shock has alot of resistance when moving it in or out. I'm
guessing it takes about 25lbs of pull to get it moving. It moves slowly as well.
I went to the Koni web site for instructions on how to set the adjustment of the shock. I set them to 3/4 of a turn from full soft as this old book that came with the car described when using 180lb coils. I hope much has not changed in the past 20+ years since it was published.
I was actually amazed that the car was raised slightly by the addition of the new springs. The Weltmeister 180lb springs were about 2 1/2" taller than the springs that came out of the car. The springs that were removed did not appear to have been cut down but were just tired.
If I had to guess, I'd say they were 140lb. The new 180lb springs actually ride smoother than the older springs. I was not expecting that result. Needless to say I am happy with the results.
