Once again John thanks for taking the time to describe your logic, I really appreciate that.
Just for fun I looked at your F/R caliper pressure ratios as you've progressed through the brake changes. You've probably already done this but for the sake of conversation here it is:
Setup 1: SC A caliper 48mm piston / 914-4 42mm piston.......1.31 F/R hyd press. ratio
Setup 2: 930 4 x 38 mm piston / 914-4 42mm piston............1.64 F/R hyd press. ratio
Setup 3: 930 4 x 38 mm piston / M (rear) 38mm piston..........2.00 F/R hyd press. ratio
As a reference point the stock 914-4 setup:
.................914-4 42 mm piston / 914-4 33 mm piston...........1.62 F/R hyd press. ratio.
As the ratio for F/R gets larger you have greater levels of hydraulic pressure in the front relative to the rear. Less regulation at the rear is possible then (everything else being equal)...
I get what you are going for now.
BTW, The valve looks like it progresses from y=.3x at max regulation to y=.5x at min regulation. As you decrease the regulation level the resolution at the knob, all other things being equal, will be reduced.
Best regards,
Kevin
QUOTE(John @ Jan 31 2007, 08:58 AM)
<SNIP>
Last year or so I found that Ferodo was making racing pads again (non asbestos) and we tried them. They seem to work really well for us. The front SC pads wore about 2x faster than the rears. With 2 drivers, we would go through a set of front pads in about 3 events.
Now that we switched to 930 fronts, the fronts last longer, but still wear out before the rears do.
The reason I would like to change out the rear calipers is mainly for cooling (vented rear rotors), but I believe that the smaller pistons will allow the prop valve to be open more.
I think that with the prop valve open more, the adjustments with the prop valve should be finer (1/2 turn would be less adjustment with smaller pistons than it was with the larger pistons).
I would always like to increase the rear braking with the car. That is one place where I could always pick up some time (deeper braking). The fronts will always do more work, but every bit helps.
just my $0.02
